How large of a tweeter can we fit in the door?
Old 10-05-2017, 09:38 AM
gonadwarrior's Avatar
Default How large of a tweeter can we fit in the door?
Trying to build an active front stage with an Sb acoustics sb17 mid and NVX's version of the sb29 tweeter and wanted to keep the interior looking stock
Will the stock location be large enough, in both diameter and depth, to house this tweeter?
size of the tweeter:
2.32" / 59.07
2.27" / 57.67 mm cutout dia
1.03" / 26.1 mm mount depth
pics for reference
Old 10-05-2017, 09:45 AM
if they're too large, I'm guessing my only option (to make these work) would be to order a spare set of OEM tweeter grills, cut them up and fabric them over
I'm guessing this will also mean removing the oem hardware behind the grill and doing some sort of custom metal work to keep the tweeter held in place
like this:
Old 10-05-2017, 04:01 PM
osu1978's Avatar
Thats a beast of a tweeter. You are probably going to have to do some fab work behind the stock grills even for significantly smaller tweeters. I had to with my focals.
Old 10-06-2017, 06:20 AM
Site Moderator
sam_spider's Avatar
Received 2,620 Likes on 1,919 Posts
You're definitely gonna have to do some work to get those to fit in the stock location, those are massive.
I think you'd be better off building a pod to place at the base of the A pillar.
Old 10-09-2017, 08:09 AM
A guy off another forum got back to me regarding this tweeter and it does indeed fit, with a little shaving of the tweeter cup, oem grille, and making a 3d printed mount
Though I am thinking now to make this a longer-term project and try to fab something up on or near the A-pillar
Old 10-09-2017, 06:09 PM
windhund116's Avatar
Received 1,443 Likes on 967 Posts
Good luck. Tell us how it turns out.
I'm running tweeters from Alpine SPS-610 kit, in door. Definite improvement over OEM. Must install sound deadening mats (I used Dynamat) to reduce buzzing at volume.
Also, Alpine KU-445A amp under dash.
Old 10-14-2017, 12:15 PM
06S2k07Si's Avatar
I did the Arc Audio variant of the SB Acoustics tweeter. The larger NVX version was too big to fit in the OEM location outside of the door. I just fiberglassed these in using the supplied cup for an OEM like look. I used the poly SB17's in the doors (https://www.madisoundspeakerstore.co...y-cone-woofer/) with homemade mdf spacers.
Old 10-14-2017, 12:25 PM
06S2k07Si's Avatar
NVX vs Arc Audio size comparison (SB Acoustics tweeters)
Old 10-14-2017, 01:00 PM
06S2k07Si's Avatar
I ran mine passive with some homemade 1700hz crossovers.
Old 10-14-2017, 04:46 PM
Clean job, on those crossovers. Love those air-core chokes. You do home systems, too?
I have a couple of JBL studio monitors which need restoration. Reconing the speakers, plus R&R the crossovers. I'll get around to them, one day.
Quick Reply: How large of a tweeter can we fit in the door?
