I cant find dip switch settings for DCI + Alpine
Old Apr 15, 2006 | 08:32 PM
payyourtoll's Avatar
Default I cant find dip switch settings for DCI + Alpine
I saw it earlier now cant find it!
Alpine head unit, what should dips be for Alpine on the IR DCI?
thanks
Old Apr 15, 2006 | 08:42 PM
Doug0716's Avatar
Umm there should be a sticker on the back of the thing...
Old Apr 15, 2006 | 08:48 PM
um thanks Doug but no there isn't
Old Apr 15, 2006 | 08:59 PM
Doug0716's Avatar
Well I wasn't trying to sound sarcastic or anything... I actually did some searching for you before I posted that and ran across this:
[QUOTE]Don
Old Apr 15, 2006 | 09:06 PM
Right, and I just need to know what dips 1+2 should be set at for Alpine
Old Apr 15, 2006 | 09:16 PM
Doug0716's Avatar
Well, maybe somebody has theirs not-installed and can help you with that...
If you've already tried all four options for the two switches and you're not getting any response then try getting a digital camera in video mode or a camcorder and use that to see if you can see the IR Light come on when you press the dash buttons.
The first one he sent me nothing worked on it, I re-checked all my wires and then used this method and discovered that it wasn't sending any signal, so I contacted him and he replaced it for me in a timely manner.
Good luck to ya.
-Doug
Old Apr 15, 2006 | 10:00 PM
Avernus's Avatar
Good luck to ya.
-Doug
now that my friends at s2ki is pure genious. props to you.
Old Apr 15, 2006 | 10:48 PM
Dave-ROR's Avatar
Uhmmm dip switches 1 and 2 aren't even used on my DCI.
It's going to depend on which version of the DCI you have.. we need more info to answer your question.
Old Apr 16, 2006 | 12:25 AM
VintageMac's Avatar
According to the Modifry DCI-2 instructions:
"Switches 1 and 2 are not used - Setting them ON or OFF will not affect the operation of the DCI".
Switch 4 is set based on whether or not you connect the DCI blue wire to the Alpine head unit. Up (OFF) if you connect the blue wire, and down (On) if you don't.
Switch 5 is set based on whether or not you want Tap-n-Press functionality. Down (ON) if you want Tap-n-Press, up (OFF) if you don't.
All the other switches (for Alpine) should be down (ON).
switchmorgan
Nov 22, 2013 02:44 PM
RsxFlyBy
Jun 3, 2010 09:55 AM
jjr197
Jul 3, 2009 09:13 AM
vinasity
Feb 9, 2006 12:34 PM
CyrusA
Mar 22, 2004 08:26 AM
