i have a auto start install problem!
Old Dec 28, 2011 | 07:56 PM
Duyx817's Avatar
Default i have a auto start install problem!
soo at the moment im trying to get my autostart working, i did all the wires correctly and i have a bypass also wired correctly and working.
the problem is, the car turns on all the electronics (heater/ac radio) but it doesn't crank?
i have read through many wire guides, and they all say the starter wire is blue and has a white line, and another guide says its a black and white line wire behind the push start button? which one is it?
and while testing to see if it auto start works, i sit in the car and push in the clutch because i have not yet did a clutch bypass
what am i doing wrong?
Old Dec 29, 2011 | 08:21 PM
TPhong's Avatar
The easiest way to test for a starter wire, is to meter the wire while cranking. It should show 12V only while you're cranking the car. What Autostart unit and bypass are you using? Try sticking the key in the ignition barrel (but don't turn it), and try to remote start it. If it cranks then your bypass isn't programmed properly. If not, it's something to do with your wiring.
Old Dec 30, 2011 | 05:21 PM
Duyx817's Avatar
thankyou for the tips!!
tekstyle
Jun 4, 2016 10:03 PM
k00leo
Dec 20, 2015 03:43 PM
usmarinedelta
Sep 29, 2015 09:19 AM
crank
Jul 12, 2013 05:51 AM
geared
Aug 25, 2012 05:49 PM
