IDA305 with DCI - help
Head unit: IDA X305
DCI: Modifry
Issue 1:
I'm using factory mute line to mute the HU.
OEM line Alpine
Yellow/Blue <--> Pink/Black
Doesn't work.... WTF.... Yellow/Blue line goes high when Mute button is pressed on the dashboard, but HU doesn't mute.....
Issue 2:
Connected Modifry DCI as per Modifry's instruction.
Doesn't work.......
Well, it can't be DCI's issue..... because even my oem mute line doesn't work!
(yes, my dash control works with OEM system, I've just double checked.)
Is there something in IDA-X305 I need to turn on to enable remote control??
HELP!!!!!
(PS, does anybody know if S2000's antenna needs to be powered. I.E. on the factory HU connecter, there is a wire called Antenna B+. what is it? Do I connect it with Power_Ant wire from my Alpine HU)
DCI: Modifry
Issue 1:
OEM line Alpine
Issue 2:
Doesn't work.......
HELP!!!!!
FIXED!!!
DCI not working:
Bad crimp on the terminal... the wire wasn't stripped properly prior to crimping.
Mute not working:
Need to connect Mute line to DCI, must go through DCI.
Hope this will help the next guy...
