Immobiliser Issues
Old Jan 5, 2017 | 08:54 AM
V-esi's Avatar
Question Immobiliser Issues
Hello, I have a 2001 (y-reg) S2000.
I parked the car up end of October 2016 and started it up every week or two until last week where the car battery died. I attached leads from my other car and the battery took a charge but the immobiliser would not deactivate.
Since then I have purchased new key fob batteries (annoying a10 size) and a new car battery although still no luck with the immobiliser.
The central locking USING KEY works fine and alarm goes off if the doors are opened. Key fobs are not responding with the car at all.
I have two fobs, neither work. Is there a way to reprogram fobs from the door locks instead of the ignition (as alarm keeps going off) or any other advise I should try?!
Everything was fine until last week which is the annoying thing :/
Regards
Old Feb 18, 2017 | 05:44 AM
Blackie4341's Avatar
Exactly the same as my MY99 AP1!!! Very frustrating.
I've just checked all the fuses (well the one's I can find anyway) and they seem to be OK.
I've also tried reprogrammng the only fob I have but the alarm just goes off when the ignition is switched on and you can't seem to access the programming mode.
Fairly sure it's a H&P system with the metal box under the drivers seat. There's another plastic box and supplementry fuse carrier cable tied up under the dash just below the starter button. One of the fuses disconnects the alarm (same as disconnecting the battery) but then the alarm sounds because it's been disconnected!!!
Anyone got any clues?
Old Feb 18, 2017 | 05:54 AM
Oh and the main battery has been on charge for a week or more and I've changed the fob battery
V-esi
Jan 18, 2017 02:55 AM
andy2000
Sep 12, 2012 08:53 AM
whaninoz
Jan 12, 2011 10:33 AM
surfer_crx
Sep 18, 2008 11:53 AM
brianrockey
Jan 29, 2006 05:56 AM
