Installed amp, cutting off on higher volumes
I finally ended up purchasing the Alpine 240 4-ch amp for my Kappa perfect 6.1 system. Currently running the stock HU using speaker-level inputs on the amp directly. I find it that if I turn the volume above ~17 the amp cuts out, then cuts back in continuously. I discovered that if I turn the bass & treble adjustment to -6 on the HU I can increase the volume up to 23 before it starts cutting again. Anyone have info why this is happening?
Is your wiring ohm stable? I've seen this when a - you don't have enough power, but you seem to, and b - when the sub is wired for an ohm load that is too low for the amp. Check what your amp can handle, and make sure you wired your sub to an appropriate tolerance - is it a dual voice coil sub?
Have you properly tuned the amp? Is the amp clipping? This sound like the amp is clipping and then sending itself into some sort of "protect" mode. Make sure the signal input on the amp is set to whatever the head unit is putting out (not sure what a LOC converter converts the high level speaker outputs to). You want to match that with the input adjustment on the amp. If you just installed it and cranked it up, you are probably clipping the signal, and sending the amp into protect.
Is there a "clip" or "protect" light on the amp? If so, the clip light should flicker no more than 1/3 of the time. Any more than that, and the amp might protect.
Check the FAQ on how to properly tune the amp.
John
John
Originally Posted by 99SH,Jan 3 2006, 03:36 PM
Happens car running or not. I'm going to try running it in unbridged configuration see what happens.
You will also want to check your main power and ground wires to see if they are getting hot.
