Installing my Headunit
Old Feb 9, 2006 | 01:45 PM
MaoGuy's Avatar
Default Installing my Headunit
OK, my alpine 9856 headunit arrived last night and i'm really eager to install it. I have all the necessary tools to install it but i remember i have the oem alarm. When i remove the negative or black wire from the battery, and put it back on will my alarm be armed or what will happen? Also, will my dash controls work with this headunit or should i purchase the modifry dash control interface. I'm so tempted to install it right now, but i'm not sure what will happen with the alarm when i do. So what should i do?
Old Feb 9, 2006 | 02:07 PM
mkbruce's Avatar
Don't know anything about the alarm, but as for installing the head unit - you will want to get Modifry's DCI - the IR one. Get his wiring harness as well as it has the extra wires needed to connect the DCI to the factory wiring without splicing. I just installed a 9856, the DCI and a pair of Polk db6500's. The improvement in sound is amazing for such a simple installation.
Good luck.
Magnus
Old Feb 9, 2006 | 02:22 PM
MaoGuy's Avatar
alright, i'm gonna go ahead and install the headunit right now. I will order the ir one for sure. thanks alot
Old Feb 9, 2006 | 02:58 PM
darkknight1999's Avatar
If your alarm goes off when you reconnect the battery just hit the disarm button on the remote to shut it off.
Old Feb 9, 2006 | 05:33 PM
NFRs2000NYC's Avatar
I would wait till you get the DCi before you install the headunit. If you install it now, you will have to redo everything again.
Old Feb 9, 2006 | 06:26 PM
PJK3's Avatar
also, as i recall - for the OEM alarm if you disarm it and open a door before disconnecting the battery, it will be disarmed when you re-power it.
aero3685
Sep 20, 2006 06:28 AM
Spec_Ops2087
Mar 2, 2006 07:58 PM
161MPHTOPSPDS2K
Nov 14, 2005 11:42 PM
funnyesq
May 3, 2003 08:56 AM
funnyesq
Apr 27, 2003 02:42 PM
