Ipod kit installation on stock head unit?
Old May 4, 2006 | 07:37 PM
suzukali's Avatar
Default Ipod kit installation on stock head unit?
Hi guys ,
i was wondering if its possible to install a ipod kit and use it with the stock head unit? Also how much does it cost to get one of those installed?
Thanks so much in advance!
-A
Old May 5, 2006 | 06:30 PM
jwa4378's Avatar
They cost around $100 (for a good one). Blitzsafe is a good product, as is the Harmon Kardon unit. Should not be too much to install (if the tech has worked on an S before.....or has a manual). You can do it yourself.....would take like an hour tops.
0. Remove center console (unscrew shift knob and just lift it up on the console and it should come).
1. Remove radio door.
2. Remove screws from radio bracket.
3. Pull radio out (unplugging the wiring harness and antenna from the back)
4. Snake the wire where you want it to go (most people run it under the center console, and into the glove box)
5. Plug wire into back to radio. Replug wiring harness and antenna.
6. Replace radio (screwing in the brackets)
7. Replace radio door.
8. Enjoy your iPod!
John
Old May 7, 2006 | 03:02 PM
Stolen R's Avatar
Are there 2 AV input jacks behind the stock headunit? If so, you could just get a L/R AV cable with a 3.5 mm jack on the other end. Something like this.
http://catalog.belkin.com/IWCatProductPage...oduct_Id=172348
Old May 7, 2006 | 03:07 PM
AusS2000's Avatar
If there was you could but there ain't so you can't.
Old May 8, 2006 | 08:43 AM
NO RIDE's Avatar
you can get the oem honda unit called the "music link". turns your cd changer port to a aux input. i had it, but i never used it and ended up selling it. the install itself looked pretty simple and straight forward.
Old May 8, 2006 | 11:13 AM
jwa4378's Avatar
That is what the blitzsafe products do.
John
Old Jan 26, 2008 | 09:09 AM
J'sS2K's Avatar
Are you going to be able to use the radio after this installlation?
Jason
Old Jan 27, 2008 | 07:21 PM
bdi's Avatar
bdi
John
ms32s2k
Jul 10, 2011 02:17 AM
ddonal2
Apr 28, 2010 01:28 PM
oo7ml
May 3, 2008 10:50 AM
Drake21
Jun 20, 2007 01:04 PM
Blk Prl
Apr 9, 2007 12:12 PM
