how to remove stock radio
Old Apr 27, 2010 | 09:26 AM
ddonal2's Avatar
Default how to remove stock radio
I am about to install my USA Spec ipod interface with my factory head unit. I have a 2006 S2K.
Do i have to remove the arm rest / center console assembly to remove the radio, or can i remove it by just taking off the fold down cover?
All i need to do is pull it out to plug in my ipod interface, i am not replacing the head unit.
thanks
Old Apr 27, 2010 | 10:16 AM
bigbodybenz's Avatar
I took my radio out of my 04 last night. I read that you need to take out the center console before taking off the radio door, so that is what I did. It is really easy; only takes a minute or two.
Old Apr 27, 2010 | 11:46 AM
sillyboybmxer's Avatar
yes ,..its just pops right off
Old Apr 27, 2010 | 12:58 PM
Almostlude's Avatar
IIRC, you don't need to take the center console off in order to pull the radio. What you need to do is put the shifter either on 2,4, or Reverse so you can get the clearance you need to pull the radio cover off, and firmly pull the radio cover off, there is a DIY stickied on this.
Even though you're not replacing the headunit, you will still need to remove it in order to get the i-pod plug on the backside of the headunit, which if I remember, is going to be your CD changer control.
Old Apr 27, 2010 | 01:26 PM
ddonal2's Avatar
yes or no?
Old Apr 27, 2010 | 02:40 PM
///KM's Avatar
I removed the center console when I did the head unit. If you want to run the iPod cable/wires through to the glove box, you probably want to run it through the center console anyway.
I don't recall if there was enough clearance to get the radio door off without removing the console, unfortunately. Console's easy enough to remove anyway, no tools needed (just your fingers).
Once the radio door's removed, there's just 4 philips screws holding the head unit that you need to remove, then the head unit slides right out.
Old Apr 27, 2010 | 09:08 PM
OldDog's Avatar
https://www.s2ki.com/forums/index.ph...ic=404767&st=0
Old Apr 28, 2010 | 11:32 AM
takeshi's Avatar
It may be different on an AP1 but with the AP2 it's a lot easier just to remove the console first IMO. I didn't see a way to get the radio door assembly off with the AP2 console in place (it buts right against the raised front edge of the console).
Old Apr 28, 2010 | 01:28 PM
Juice Steez's Avatar
suzukali
Jan 27, 2008 07:21 PM
Timphan84
Dec 1, 2007 06:27 AM
tks2000
Jul 9, 2007 08:46 AM
Blk Prl
Apr 9, 2007 12:12 PM
SLstone s2k kid
Jan 19, 2007 01:00 PM
