JL Audio 10w3v3
Old Aug 10, 2016 | 11:30 AM
s2jay again's Avatar
Default JL Audio 10w3v3
after lots of reading and researching, I have decided on 1 JL Audio 10w3v3 in a zenclosures toolwell box. not sure which one to order though between the 2ohm and 4ohm versions. which one is everyone using?
also, i'd like to also power it with a JL Audio amp, but have no clue which is the right one. search doesnt provide many specific details.
forgive my ignorance on the subject and Thanks in advance.
Old Aug 11, 2016 | 06:53 AM
lovegroova's Avatar
Useful guidance on the JL website: http://www.jlaudio.co.uk/10w3v3-4-ca...-drivers-92151
Clicking the specifications tab suggests a power output of 250W, so one of JL's 300/1 amps (HX, XDv2, will do nicely). If budget is tight, then the JX250/1 will do the job.
Old Aug 11, 2016 | 11:04 AM
Thanks for that!^ and you linked me to the 4ohm sub, is that the one i want??
Old Aug 12, 2016 | 04:52 AM
lovegroova's Avatar
No idea, I'm afraid. That's what google took me to. I suspect there is little difference.
Old Aug 12, 2016 | 08:44 AM
oth's Avatar
oth
Many amps produce more power (watts) with a lower impedance (ohms) speaker, though at some point the impedance
is too low for the amp. If you have an amp only rated down to 4-ohms, then you definitely want a 4-ohm sub.
Most multi-channel amps when bridged (combining two channels into one) are only stable down to 4 ohms; many
single-channel amps are stable to 2 ohms. Some amps produce the same power into 2 and 4 ohms, so you'd get
no power advantage with the lower impedance sub. HTH
Old Sep 2, 2016 | 04:39 AM
Charper732's Avatar
I just got a v3 last week. This sub is by far the best bang for buck.
90% of users will need the 2 ohm version. Its rare to buy the 4 ohm.
As far as the amp goes, i already had a 750/4 thst im using but if i were to need to buy one, i would go with the JL 500/1
Old Sep 3, 2016 | 05:01 AM
osu1978's Avatar
I would would also go with the 500/1 amp as recommended in the prior post for your 10w3.
I went with a 10" alpine type r since it fits well within the darkside v2 enclosure for our cars. Saves a lot of room and pounds hard.
1st07inOH
Dec 6, 2007 06:26 AM
Brutewes
May 18, 2006 08:34 AM
AndyS2
Jan 14, 2004 05:39 AM
Tuan Le
Apr 17, 2003 01:39 PM
145
Feb 28, 2003 12:30 PM
