KDC-x679
Old Apr 24, 2004 | 05:11 PM
overkill's Avatar
Default KDC-x679
I have a kdc-x679 that plays for about two seconds then shuts off. I checked all the connections and they appear to be correct, without short circuits. I even tryed to run it without anything else connected but the power wires. When i try to reset it, it runs untill i press tuner or cd, plays for two seconds then shuts off. What do you think the problem is?
Old Apr 24, 2004 | 05:17 PM
Toxis's Avatar
I'd say the radio is jacked up. Take it back where you bought it and get a new one. If it shuts off the second you turn on signal, it could be internal (internal amp with a short), wiring (wires crossing each other) or the speakers (they could be grounding themselves out causing the amp to shut off). If it shuts off even with the sources off than it's the deck. Hope this helps.
Old Apr 24, 2004 | 05:45 PM
overkill's Avatar
Thank you.
It sounds like the internal amp is shorted. The back of the receiver seems to get "hot" although it could be my imagination. I'm afraid you could be right.
Old Apr 24, 2004 | 05:49 PM
Toxis's Avatar
How long have you had it? Within 30 days and your retailer will have to replace it (pending them having weird return policies).
ar10
Apr 19, 2015 08:37 AM
Truvietz916
Apr 7, 2009 11:20 AM
DDuds2k
Aug 13, 2007 05:13 PM
145
Jul 9, 2002 06:06 PM
ErikKlenke
Jul 16, 2001 01:00 PM
