Modifry DCI Volume button control problem
Old Nov 3, 2009 | 05:58 PM
bam9382's Avatar
Default Modifry DCI Volume button control problem
Hey all,
Installed a modifry DCI about 1.5 yrs ago and about 6 months ago my volume controls starting go crazy and not when i press volume up.. it changes sources and when I press volume down it turns the volume up.. i finally pulled it out thinking that the switches got changed or something and I double checked everything to the install instructions on modifry.com... and cant get it to work right??
I have a pioneer radio, does anyone know if I may have changed a setting on my radio one day that did this? any ideas?
thanks
Old Nov 3, 2009 | 07:07 PM
bam9382's Avatar
bump.. help please?
Old Nov 4, 2009 | 09:04 AM
oth's Avatar
oth
The dash switch works by grounding the wire through different resisters - the DCI
measures the resistance and decides which button(s) you've pushed.
As you can see on Modifry's tech page, it looks as though the DCI sees more
resistance than it should. It could be a bad DCI, or it could be a bad splice or other
connection in a DCI wire causing additional resistance.
You can troubleshoot using the ohm setting on a multimeter.
Old Nov 4, 2009 | 09:47 AM
bam9382's Avatar
So which wire specifically should i pay attention to that may be causing this? I will go back and check that one closely. Ground wire? or one of the colors?
Old Nov 4, 2009 | 12:19 PM
oth's Avatar
oth
the DCI green wire is the one that leads to the dash switch and is the
most likely culprit.
Old Nov 5, 2009 | 10:18 AM
bam9382's Avatar
thanks man, i will check into it today and let you know what happens
Old Nov 6, 2009 | 09:09 PM
bumbota111's Avatar
Originally Posted by bam9382,Nov 3 2009, 06:58 PM
Hey all,
thanks
I had a similar problem as well. Here is my thread. If you done all the checks I have I would contact Bob.
https://www.s2ki.com/forums/index.php?showt...&#entry16642257
hsuis2cool
Jan 6, 2009 12:22 PM
LS Boy
Jan 27, 2007 03:15 AM
Rich04
Dec 12, 2006 08:28 AM
cw_huntington
May 23, 2006 07:57 AM
Ajjra
Feb 20, 2004 01:53 PM
