modifry wired dci controls not working
Old Feb 21, 2010 | 04:13 PM
Thefbomb13's Avatar
Default modifry wired dci controls not working
i just bought the modifry wired dci with the pioneer wiring harness for my Pioneer DEH7100BT and i wired everything perfect with soldering and heat shrink but for some reason the steering wheel controls aren't working... i don't understand.. i have the the 3.5mm jack in the w/r input and i've tried all the settings but it just won't work can anyone tell me what im doing wrong?
Old Feb 22, 2010 | 08:17 AM
kamal's Avatar
did you adjust the sliders to the pioneer setting? There's 4 sliding switches/toggles that have to be set either up or down, depending on application. Look into the FAQ on modifry's site.
Old Feb 22, 2010 | 11:05 AM
zeroptzero's Avatar
I just put mine on , it didn't work either, but then I adjusted the dip switches and the buttons started working after that. My mute button is dead though, not a fault of the dci, it is a common problem. My DCI had 8 dip switches but the instructions on the website showed settings for 4 switches, I later found alternate information on the other 4 switches and that is when it started to work.
If you have it wired properly and the dipswitches are in the proper setting then either the car remote switch is dead or the dci is deat. Unfortunately getting a hold of bob at modifry can be quite the challenge.
Old Feb 22, 2010 | 01:00 PM
huberc's Avatar
I have the same setup..DCI + deh7100BT working fine, so the two are definitely compatible. My mute button toggles the "attenuate" feature of the headunit rather than mute.
I'm using the "tap and press" version of the commands by the way.
Kyle
Sep 14, 2018 12:22 AM
goneinseconds
Feb 21, 2016 05:38 PM
sandman
Aug 13, 2009 02:15 PM
rail157
May 19, 2009 02:39 PM
Huron
Aug 7, 2007 10:52 PM
