Modifry DCI issue
Old May 19, 2009 | 11:55 AM
rail157's Avatar
Default Modifry DCI issue
My DCI has been acting pretty weirdly lately. I'm using Modifry's Alpine DCI with his plug and play harness on an Alpine X100(red lighting, dimmer off). It started out pretty infrequently, but it's gotten to the point where it does this several times every drive. It'll be working fine, then the volume switch will start increasing the volume whether I'm pushing up or down. Sometimes it goes back to normal after a bit, sometimes the DCI stops working until I cut the power and restart. The only button that works consistently is the Mute button. The wiring is all solid, and the dip switches on the DCI are all set correctly.
Does anyone have any ideas? I'm afraid that my DCI is bad, but I'm hoping there's another solution that I'm missing.
Old May 19, 2009 | 01:00 PM
SgtB's Avatar
Make sure the connection to the dash wire is still good, and the plug is firmly installed into the headunit. The dash control is resistance based, so a loose connection will throw it off.
Old May 19, 2009 | 01:40 PM
rail157's Avatar
That's the green one, right? I'll go check it, thanks.
Old May 19, 2009 | 01:54 PM
rail157's Avatar
As it turns out, SgtB, you were right. The green wire was a little loose, it was merely a matter of removing it from the socket and spreading the connector a little wider.
Thanks again.
Old May 19, 2009 | 02:39 PM
SgtB's Avatar
No problem.
Kyle
Sep 14, 2018 12:22 AM
sandman
Aug 13, 2009 02:15 PM
Huron
Aug 7, 2007 10:52 PM
Allstar
Jan 20, 2007 08:02 PM
iLuveketchup
Sep 17, 2006 01:02 PM
