most bass without a sub?
Old Mar 15, 2003 | 02:14 PM
payyourtoll's Avatar
Default most bass without a sub?
aftermarket hu, 4-chan amp running 6.5 components and 5.25 rears is my best bet? any specific model recommendations are welcomed
Old Mar 17, 2003 | 01:14 AM
modifry's Avatar
Honorary Member
Highest Xmax you can find and dynamat the doors.
Sorry I don't have any specific driver recommendations, but when you're shopping ask for the "X-max" specification for the woofer. It will be listed in the driver specs along with a bunch of other "T-S" parameters. This is one spec that has more influence on bass reproduction than many people realize.
It's a number, usually in millimeters, that indicates the maximum one-way excursion (in-and-out travel) for the speaker cone. Good, loud bass production requires a lot of air movement, and there are only 2 ways to do that - either a large surface area for the speaker cone (bigger drivers or more of them) or you need to move that cone farther (Xmax). For each octave lower you want to go in bass repoduction you need 4 times the speaker excursion to produce the same sound output. This means that it takes 4 times the cone excursion to produce 100 Hz at 100 dB as it does to produce 200 Hz at 100 dB. And if you are after 50 Hz (and you should be), it takes 16 times the excursion compared to 200 Hz. Many speakers simply run out of excursion capability long before they reach maximum operating power, and that severly limits bass output.
Expensive subs will often have Xmax ratings of 15mm or higher, but you can't put those in the doors and they don't reproduce the midrange worth a crap so you wouldn't want to. For a 6.5 woofer, I would try to find drivers with at least 3mm Xmax rating and the lowest resonant frequency (called Fs) you can find. For Fs, expect numbers between 50 and 60 Hz. Higher than 60 Hz - find another driver.
Old Mar 17, 2003 | 04:35 AM
thank you
I know what to look for now in the speakers.
With an aftermarket hu, putting out say 30w rms per channel, would it greatly benefit me to be running an amp to the components AND the rear 5.25s? If I do run an amp to the fronts, do I HAVE to replace the speaker wire, or is it just highly recommended? Ive searched and found mixed answers...
Old Mar 17, 2003 | 09:17 AM
ricosuave's Avatar
get an aftermarket 4-channel amp to run all four speakers. you have better control of the gain and therefore better efficiency at powering the speakers.
imho, you get better sound quality from an amp too.
the lower gauge the wire, the better. i'd recommend it (pita for the fronts).
Old Mar 17, 2003 | 03:32 PM
modifry's Avatar
Honorary Member
[QUOTE]Originally posted by payyourtoll
[B]thank you
S2Kmonkee
Jan 25, 2010 03:17 PM
S2Kmonkee
Jan 10, 2010 10:13 PM
dan_uk
Jul 5, 2008 01:34 PM
Shamu
May 25, 2002 08:27 PM
Cyberorth
Apr 5, 2002 01:17 AM
