mounting an amp on the underside of the trunk lid?
Old Mar 12, 2009 | 01:20 PM
street_ruler's Avatar
Default mounting an amp on the underside of the trunk lid?
so i was thinking ways of saving space in the trunk...anyone ever mount an amp on the underside of the trunk lid? im thinking that you could finable it so you could drill into the "skelliton" of the trunk lid for mounting purposes and if it were a digital amp you could mount it upsiude down. this would keep it off the floor and allow for more useable space. anyone done this?
Old Mar 12, 2009 | 04:09 PM
Penforhire's Avatar
You'd have to seriously beef up the springs. I've just got a Muz saddlebag up there and my lid barely pops open as it is. Otherwise, and accounting for flexing cables every time you open it, sounds like a neat idea.
Old Mar 12, 2009 | 06:24 PM
goldenfri's Avatar
I had two alpine amps mounted like that, didn't really save much space because they came down and took up a lot of room once you closed the trunk. It worked fine with screwes screwed into the part of the trunk that was away from the top I also used wood spacers so give me some distance from the trunk.
Also no need to beef up the springs it should work fine.
Old Mar 16, 2009 | 12:18 PM
how/what can you use to beef up the springs? or are there factory springs for cars with and without a spoiler that might be stiffer/better for this?
Old Mar 16, 2009 | 06:58 PM
schmittx's Avatar
if you want to stay with OEM parts, the springs for the CR trunk lid would be the best option...that spoiler is the heaviest when compared to the normal wing spoiler or lip spoiler...not sure if it'd be enough for the amps you want to mount?
Old Mar 17, 2009 | 06:16 AM
whats a non OEM option?
Old Mar 17, 2009 | 11:52 AM
camuman's Avatar
just buy the springs that come with the spoiler package. people install the spoiler and skip the springs. thats how i picked mine up. i have a jl audio 5 channel 500/5 up there. works fine and stays up by itself. lemme try and did up a picture.
heres when i had big ppi amp up there.
https://www.s2ki.com/forums/index.php?showt...0&#entry7156250
heres my current amp installed on underside of trunk lid.
ttang
Jul 6, 2011 09:01 AM
Purple Haze
May 17, 2011 12:01 PM
johnvtha1
Mar 10, 2009 05:17 PM
iheartap1
Apr 23, 2008 10:54 AM
jwa4378
Jul 1, 2005 05:52 AM
