my setup
Old May 31, 2001 | 02:05 PM
blondie's Avatar
Guys,
Here's what I ended up doing:
Speaker: Sony 3-way ES1655G
Amp: Kenwood KAC-829
Keep the stock headunit
It was somewhat painfull to install the speakers, but they fit O.K. You will need to cut much of the baskets though. I also used a foam basket from Crutchfield, but cut a large square-shaped hole on the side for the wires as well as "breathing". Currently the amp is attached to the trunk floor with velcro, but at some point I may need to enhance that setup. So far, the velcro is holding up. Sound quality and quantity are vastly improved. However the amp is an overkill for any 61/2" speaker. On the plus side, I can only crank the headunit volume by 4-5 ticks, which means I don't feed much distortion into the amp. I rewired the speakers, and had to cut into the wires right out of the harness for the speaker-level line wires. I used the under-the-door scheme to route all the wires. Power on the right side, all signals on the left. FYI.
Old May 31, 2001 | 02:14 PM
s2kblk's Avatar
How many watts per channel is the amp? I assume it's plenty for top down driving right?
Old May 31, 2001 | 02:18 PM
blondie's Avatar
100w rms * 2 into 4 ohms. Peak power handling is twice that. It is satisfactory top down, but bottleneck is the speaker, and not the amp. It is not even getting warm!
Old Jun 2, 2001 | 04:37 PM
lucid's Avatar
why bother keeping the stock head? I'd rather run RCA patches to the amp for more clarity.
S2K Type R
Apr 16, 2010 11:16 AM
s2k_redhead
May 28, 2003 03:22 PM
ErikKlenke
Jul 16, 2001 01:00 PM
ErikKlenke
Jul 16, 2001 12:01 PM
dirt
Jun 26, 2001 02:44 AM
