MY04 proximity sensor location help
Old Jun 26, 2006 | 08:11 PM
sund's Avatar
Default MY04 proximity sensor location help
I'm trying to add a proximty sensor on my 2004. Does anyone have any suggestions on where to mount it? I found some pics of installs on previous years, but the sensor doesn't seem like it has enough room to mount it and put the center console back on. I also tried taking the sensor out of the casing and the only place that seems to fit is right below where the cupholders are.
Any suggestions are appreciated.
Thanks.
Old Jun 27, 2006 | 02:46 PM
Kabomo's Avatar
My prox. sensor fits under the center console. It's not directly under the cup/misc. stuff holder, but more under the metal framing that the center console snaps into. I believe velcro strips are used to hold it down.
Old Jun 27, 2006 | 03:49 PM
sund's Avatar
Kabomo,
Thanks for the reply. Is it more towards the shifter or closer to the back of the car compared to where the cupholder is?
Thanks,
Sun
Old Jun 30, 2006 | 12:29 PM
modifry's Avatar
Honorary Member
Mine is mounted under the padded section of the center console, just ahead of the accessory power plug. There's a cut-out in the sheet metal about 3x4" if I remember right.
Old Jun 30, 2006 | 08:53 PM
PJK3's Avatar
yup, mine is where Bob's is...
(btw, Bob - LOVING the camera mount. even with my big honkin' camera, the footage was great and more stable than I had even hoped! )
Old Jul 1, 2006 | 07:42 AM
Will's Avatar
My prox sensor is mounted in the secret compartment, in the larger of the two compartments. Works well.
Old Jul 1, 2006 | 09:59 AM
sund's Avatar
Thanks for the replies. I ended up mounting it underneat the cupholders as I couldn't find anywhere else. The padded section didn't seem like it had enough room as the sliding door for the cupholer ran into that area. Seems to be working fairly well. There is a bit of metal surrounding the area, but it seems to pick up motion. I'll keep testing.
Old Jul 1, 2006 | 10:26 AM
Kabomo's Avatar
Hey Sund,
Sorry...forgot to check back. But mine is located toward the back under the padded side. It seems to fit with a lot of room around it...I wonder what kind of sensor you have.
Old Jul 1, 2006 | 10:42 AM
Saki GT's Avatar
[QUOTE=modifry,Jun 30 2006, 03:29 PM] Mine is mounted under the padded section of the center console, just ahead of the accessory power plug.
#172CR
Mar 16, 2009 01:13 PM
hi-revs
Jan 10, 2009 04:17 PM
captainbk
Jun 24, 2008 06:13 PM
bboyd
Mar 11, 2003 11:04 PM
Power6Spd
Nov 6, 2000 07:59 AM
