MY2004+ Rear Speaker Connector
Old Jul 5, 2005 | 11:00 AM
tomcapek's Avatar
Default MY2004+ Rear Speaker Connector
Looked for the rear speaker connector on my 2005 that is suppose to be taped to the factory speaker harness. Instructions for the install of the factory rear speaker kit says that it should be just under the instrument panel, driver's side. (Didn't buy this kit but still want to know where the d*mn connector is) I eyeballed the harness and could not find it.
Is it directly behind the HU?
Am I going to have to pull the HU out to locate it?
Old Jul 7, 2005 | 08:17 AM
converted's Avatar
It isn't easy to get to. It is on the driver's side. The easiest way to do it would be to remove the stereo. It's hard to access otherwise. I found it using a flashlight and laying myself in the floor board. I had to remove the somewhat triangular panel on the left of the stereo. in order to see it. I used a long blade knife to cut the tape and then used the knife to move it to where I could get a hold of it. Probably could of used some needle nose pliers...it would have been safer. If you need further help send me a PM and I'll give you my number and talk you through it.
Argetni
May 5, 2011 09:32 AM
RickFriend
Jul 10, 2008 11:04 AM
ignition25
Feb 10, 2007 08:53 AM
Sidewinder
Apr 22, 2004 09:47 AM
joecro
Sep 9, 2001 10:49 AM
