Need Advice
Old Nov 29, 2009 | 08:30 AM
YLDS2K's Avatar
Default Need Advice
Hi guys,
After many hours of research and pulling out my hair on which set of speakers i should get for my newly purchased 01 s. I have come to the conclusion that i would like to get the 165VR 6.5" component speaker set.
http://www.focalaustralia.com.au/pdf...lass_165VR.pdf <<<PDF file
My question to those who read this is, will they fit with a 70mm mounting depth? I dont mind making up a MDF spacer or cut out the rear plastic basket, i think i read up somewhere while i was searching that you can fit up to 90mm if thats the case, then, fantastic.
If these fit i will continue to put myself through the same stress trying to choose a amp, HU and sub which i will most likely ask you guys
any advice is helpfull as long as its constructive.
Thanks in advance
Old Nov 30, 2009 | 11:27 PM
YLDS2K's Avatar
ok so no1 knows the standard mounting depth of the S?
Old Dec 1, 2009 | 01:03 AM
lovegroova's Avatar
My SPX-177Rs have a depth (per the manual) of 2.8" or 70.8mm, and need a spacer ring to fit.
Your link doesn't say how deep the Focal is, but I konw a lot of folk in the UK use them, I suspect with a spacer ring.
HTH
Old Dec 1, 2009 | 07:40 AM
Neutered Sputniks's Avatar
The mounting depth of the door to window is 53mm. Given a 3/4" spacer (19mm), you can fit up to 72mm mounting depth.
A 1" spacer (25.4mm) gives a total of 78mm depth, however use of a 1" spacer requires shaving the rear of the door speaker grill.
vansman
May 1, 2014 02:13 PM
07BBS2K
Jan 31, 2009 03:25 PM
kaiske
Jan 10, 2007 05:30 PM
JayStyles662
Nov 5, 2005 12:32 PM
S2kRob
Mar 9, 2004 05:52 AM
