Will these speakers fit?
Old Jan 29, 2009 | 02:00 PM
07BBS2K's Avatar
Default Will these speakers fit?
I am planning to order these speakers but before I do I want to know does it fit?
http://www.edesignaudio.com/product_info.p...products_id=617
Old Jan 29, 2009 | 02:35 PM
Eric220's Avatar
Those should fit with some modifications. They are slightly bigger in diameter and mounting depth compared to others, I think the depth is 2.5". I'd like someone to confirm though.
Old Jan 29, 2009 | 03:05 PM
ryanmatic's Avatar
Yeah, you're definitely going to have to play around with those to get them to fit.
I tried installing these Pioneer components yesterday, and the woofer was too thick for the door without a custom mounting bracket (the door panel wouldn't fit back on after both mounting brackets were installed). The Pioneers I'm talking about have a mounting depth of somewhat over 2.5".
Old Jan 29, 2009 | 03:27 PM
07BBS2K's Avatar
How can I make it fit? I don't want to cut anything. Are there any speakers that fit perfectly?
Old Jan 29, 2009 | 03:35 PM
megalomaniac's Avatar
Yes they will fit. My Alpine type R's are deeper then that. One thing you will have to do is space the speaker out some. I used the factory spacer the the factory speakers sit in. If you cut out the bottom then you have a pretty good spacer. If you dont have those, most audio stores sell spacers, so just find one that will put your far enough out to clear the window but not to far as to hit the door panel.
Old Jan 29, 2009 | 03:39 PM
Another factory speaker is about the only speaker that will fit "perfectly." Most Honda speakers come in this little bucket/houseing that if you want to put an aftermarket spearker in you have to cut the bottom of it our or get a spacer. If you mount straight to the metal then you'll hit the window.
Old Jan 30, 2009 | 09:19 PM
07BBS2K's Avatar
megalomaniac
Thanks for clearing it up for me.
Old Jan 31, 2009 | 03:25 PM
Neutered Sputniks's Avatar
Lies.
My Diamonds are mounted with no spacer and don't hit the window.
Mounting depth is 2.2" without a spacer. If you have a spacer, add the thickness of the spacer (usually 3/4" MDF) to that mounting depth (for a grand total of 2.95" depth).
vansman
May 1, 2014 02:13 PM
MB
Jun 7, 2010 10:57 AM
ExoticCarSite
Jul 25, 2006 03:15 PM
CHUCKLIDDELL101
Feb 22, 2006 06:19 PM
JayStyles662
Nov 5, 2005 12:32 PM
