Need feeback from audiophiles
Old Jul 20, 2009 | 12:30 PM
Agate's Avatar
Originally Posted by DG_HTX,Jul 20 2009, 12:59 PM
Thanks for all the helpful info!!! As for the front speaker mounting depth; I've heard anywhere from 2"-2 1/2". I was considering spacers if speakers are too deep. Will spacers have a negative impact on sq?
Spacers shouldn't affect SQ, but will have fitment issues with the door panel if they're too thick. I think I've heard the deepest you can fit with spacers, without modifying the door panels, is 2.75".
Old Jul 20, 2009 | 12:42 PM
Neutered Sputniks's Avatar
Mounting depth from the door to window is 54mm (at the top of the opening, bottom of the opening s 61mm).
A 3/4" spacer adds approx 19mm, for a recommended max of 73mm (or approx 3" since very few magnets are 6 1/2" diameter...)
Contrary to popular belief on these forums, an increase in speaker quality is indeed noticeable (even at speed, with the top down). There is a distinct difference between my old Diamond tweeters and my current SEAS tweeters - at highway speeds, with the top down, with only 65W/tweeter (slightly underpowered). Mainstream tweeters tend to be bright (and woofers are muddy). This is because of excellent marketing - the speakers don't really replay music all that well, but most kids couldn't care less - they just want something that seems loud. So speakers (and amps/HU's/etc) are designed to make the music "loud" - this means boomy bass out of subs and woofers, low quality midrange, and bright tweeters. Because the distortion tells kids that it's "loud." The great irony is that a very high quality SQ system will be as loud as most of those systems - without causing the same level of listener fatigue. Oh, yeah, and those Diamond tweeters (that receive excellent reviews) cost over 2x as much as my SEAS tweeters ($160 from a dealer vs $70 from a dealer).
And Claus, I have my reasons for hating on Alpine... I believe it is possible to have a not-so-bright system using Alpine HUs...but you have to work MUCH harder to find speakers that will allow that to happen. I also have heard at least one story of Alpine "quality" that leaves me able to assure everyone that I will not only never buy Alpine products, but I will never install Alpine products for anyone else either. That's without even getting into my experience with Alpine HU's...
Old Jul 20, 2009 | 01:16 PM
Claus's Avatar
Originally Posted by smurf2k,Jul 20 2009, 08:53 AM
no complaints on BA pros. powered by alpine pdx 4.150
edit: in a noisy environment like s2k, i dont think you'll appreciate the minute differences between any of these. as long as it gets loud and clean
if you are in socal, I can give you a ride to show you the difference
Old Jul 20, 2009 | 02:09 PM
Likewise for anyone in the NE
Old Jul 20, 2009 | 02:29 PM
And, just to clarify the comment about how much I've spent...
Currently the system in my S would cost approx $2300 to replace (not including the Revelators - that bumps it to $2700).
Currently the system in my truck would cost approx $3k to replace.
The amazing thing is that the truck has 4 amps, the car has 2. Audison and JL are expensive, Sundown is far less expensive with at least the same SQ (if not better). Doing the car build all over again, I would run pretty much the same setup, but would save quite a bit by running Sundown amps and less expensive door speakers (because the Sundown amp would put down enough power to handle 8ohm impedance - SQ improvement and cost savings over the Revs). The truck system was built with the end goal in mind, the S system was somewhat pieced together.
Keep in mind that the $6k I have in stereo equipment right now does NOT include the $10k I have spent over the years on equipment I no longer even own. The truck and S are perfect examples. The truck has had nothing upgraded since I did this build and given the SQ, nothing ever will need to be upgraded (replaced when broken/blown is a different story). The S, on the other hand, started without a real goal in mind other than just having a system. So it's on it's 2nd sub, 2nd mid-range amp (admittedly to switch from passive to active, but still counts as an upgrade), 2nd set of door speakers. Think about how much I would have saved over the past year or so just by buying what I will wind up with (at least $250 for the sub, $150 for the amp, $250 in speakers).
Old Jul 20, 2009 | 06:22 PM
DG's Avatar
DG
Taking your recommendation on the seas speakers, i went on their website but just got more confused. They have 3 different lines excel, prestige, and exotic. Which one do you recommend?
I thought I had some understanding of audio, but the more I read both of your postings it's obvious that I don't
Old Jul 20, 2009 | 09:37 PM
That happens to me a lot too
The speakers I have in my truck are SEAS Prestige (woofers and tweeters). The same tweeters are in my S. The woofers for my S (that I'm building enclosures for) are ScanSpeak Revelators.
The amp you purchase will have as much of a say as mounting depth does. There are really 2 elements to picking a speaker - how much power it needs/you have and if it will physically fit
So, while I could build spacers to make most of the SEAS line fit in my S, because they are 8ohm speakers, they would be woefully underpowered (65W/2 = 35W @ 8ohms, not enough). That wasn't an issue in my truck as I have a 50x4 (or 160x2 @ 4ohms) amp for each door so running at 8ohms I had 80W on tap for the woofers (and turned the gain WAY down for the tweeters).
If you're picking up both the 4-channel amp and speakers at the same time, then you can tailor each to match - i.e. pick up 8ohm speakers and a 125x4 @ 4ohm amp - that's essentially 65x4 @ 8 ohm which would be powerful enough.
Make any more sense?
When shopping for woofers I would steer clear of anything with either an uncoated paper cone (you'll have to build fiberglass pods or water will cause the cones to melt) or a metallic cone (metal cones resonate at certain frequencies and thus reduce sound quality).
Probably the best choice for tweeters is to go to http://www.madisound.com/catalog/ind...ath=45_245_313
Any of the SEAS or LPG tweeters offered will be excellent. The SEAS tweeters are the same except for the dome (one is textile, one is metallic). A metal dome tweeter will tend to be brighter, while a textile dome tweeter will tend to be slightly warm.
TraviS2K
Dec 29, 2007 09:03 AM
HeliFlyer
Oct 11, 2005 05:29 PM
xjohnx
Mar 31, 2004 09:59 PM
preppyS2000
Feb 11, 2004 01:34 PM
vrod
Sep 18, 2003 05:29 PM
