Need Help Locating Keyless Entry
Old Oct 5, 2002 | 08:12 PM
GPW02S2's Avatar
Default Need Help Locating Keyless Entry
Where is the Keyless Entry Unit on the S2000? I am trying to rig the wires so that when I unlock my car the windows go down and when I lock the car, the windows go up. So where can I locate the Keyless Entry Unit Trigger wires? Thanx in advance
Old Oct 5, 2002 | 10:11 PM
kobiejoohn's Avatar
According to the info I have it is in the driver kick panel behind the start button. Lock wire is pink/black and unlock is yellow/green & pink/blue. Hope this helps.
Old Oct 5, 2002 | 10:44 PM
GPW02S2's Avatar
Thanx a lot kobiejoohn. I will check it out tomorrow morning to see if this is what I am looking for. I will keep you guys informed and see what the end results are.
Old Oct 6, 2002 | 11:26 AM
GPW02S2's Avatar
Looked at it today and this is the location of the ECU. I am looking for the location of the Keyless Entry Unit. Anyone know where it is located?
Old Oct 6, 2002 | 01:37 PM
jeffbrig's Avatar
Look up, it's not behind the kick panel, it's beind the dash, left side of the steering column, way up high. If you stand on your head in the driver's floorboard, you can barely see it way up there. Keep a flashlight handy, the label says keyless entry, but it's hard to see. I had to find it when I was installing my alarm last weekend.
Old Oct 6, 2002 | 02:02 PM
GPW02S2's Avatar
Thanx jeffbrig! I am going right now to check it out
Old Oct 6, 2002 | 02:40 PM
GPW02S2's Avatar
I found the Keyless Entry Unit, only one problem, I dont know what wires I am supposed to cut and where to lead them to in order for the windows to go up and down when I lock/unlock the car. Is it possible to do this w/o purchasing the Autoloc WC1000 or the DEI 530T?
Old Oct 7, 2002 | 02:32 PM
modifry's Avatar
Honorary Member
The keyless unit will only have wires for lock and unlock if your car came with the Factory Alarm option.
Without the factory alarm, the wires are not installed. The good news is the keyless unit still has the functionality for it, but you have some work to do.
If you have the factory alarm, the wires you want are # 11 (green/red) and 12 (black/white). To make it easier to find, look for 2 yellow wires together at one corner of the connector, they are wires 9 and 10. The 2 next to them are 11 and 12.
If you are without the factory alarm, they are the 2 holes without wires. You can either solder wires directly to the pins on the module and run the wires out through the holes in the connector, or you can pop the clip off the module (easy) and slide out the printed circuit board and solder wires to the board (what I did).
You connect the wires to ground to unlock or lock. I don't remember which is which, but once you find them, that's easy to figure out.
Old Oct 7, 2002 | 03:26 PM
GPW02S2's Avatar
But is there a way to make your windows go up/down when you unlock/lock with this system?
Cayne82
May 4, 2014 08:13 AM
S2K Type R
May 22, 2008 10:51 AM
viper7169
Apr 26, 2006 06:46 PM
B.C.
Jan 25, 2006 09:57 PM
