No Bass :(
Old Sep 14, 2010 | 10:58 PM
tukluc's Avatar
Default No Bass :(
I have the following system:
Speakers:
JL Audio 8Wv3 Sub in a Wlaurent box
Boston Acoustic Pro 5.2
Boston Acoustic Pro 4.2 (in S-pods)
And just recently upgraded my Alpine deck and Fosgate Amp to the following setup:
Alpine iDA-x305s
Alpine PDX-5
My question is this....my sub sounds like its getting very little signal from the amp. I have maxed the gain and played with the subwoofer attenuation in the deck but still it doesn't have the same punch it did when I had it hooked up to a Fosgate amp.
Its almost like there is a defeat switch in that the low frequencies aren't finding their way to the amp and subsequently to the sub.
Any thoughts?
Old Sep 28, 2010 | 09:30 AM
yepesd's Avatar
still having this problem?
Old Sep 30, 2010 | 09:36 AM
trebor8915's Avatar
I have the ida-x305. (not the s). Check your setting on the HU. Hold down the sound button to get to the menu. Let me know if you need additional help.
Old Sep 30, 2010 | 10:18 AM
darkknight1999's Avatar
Did check to make sure the amp and sub are wire correctly to work together? 2ohm vs. 4ohm? Also did you program the new amp and the deck in the menu options?
Im sure it has to be a simple fix. I have a set of 3 ways in the doors, 5.25 rears behind the seats and an Alpine type-r 12" in a sealed box on that same amp... and its so loud you need ear plugs.
christoepurrr
Jan 31, 2010 12:16 AM
neoarroyo
Aug 6, 2007 09:19 PM
ness1216
May 30, 2006 07:46 PM
SilverstoneS2k_FL
Feb 21, 2005 04:36 PM
TampaS2k
Sep 16, 2002 03:51 AM
