Parallel Or Serial?
Old Jul 21, 2004 | 01:01 PM
Go_Nads's Avatar
Default Parallel Or Serial?
Hi
I have a Phoenix Gold Octane R8:0.4 (4x75W RMS at 4ohm)
I am going to get a 8" Dual Voice Coil 4ohm Rockford Fosgate Punch HX2 RFD2208 which is rated at 400W RMS (200W per channel)
If I bridge 2 channels to the sub and wire it in Parallel will it run at 2ohms Ok?
I was told that I may need to get a 2ohm DVC and run it in serial to get 4ohms for the amp to run in a bridged mode. Is this true?
Thanks
Old Jul 21, 2004 | 05:01 PM
PJK3's Avatar
looking at this page:
http://www.phoenixgold.com/2004/octane-ramps.html
it looks like the PG R8:0.4 will peak at 400 W x 2 when bridged, and is stable only to 4 ohms when bridged.
this sub will work fine as it has a peak power handling of 800 W total and each coil is 4 ohms. you'll want to brdige your amp to 2 channels, then run each bridged pair to 1 voice coil. be sure to send a MONO signal to the amp.
DFWs2k
Apr 15, 2009 08:25 AM
madkimchi
Apr 2, 2009 08:06 PM
mugenrsx
Nov 2, 2008 09:07 AM
steve0617
Mar 8, 2004 12:42 PM
TIMELESS
May 6, 2002 04:17 PM
