Problems with stock Head-Unit?????
Old May 13, 2002 | 12:03 PM
Whitelightning's Avatar
Default Problems with stock Head-Unit?????
I pulled an amp wire and my head-up is blank with anti-theft blinking... any ideas on what to do? I think it is suppose to pop up with "Code" before you can enter the code for it,.... I have tried the code and had no sucess...My amp IS hooked back up just like it should be????
Old May 13, 2002 | 12:18 PM
astig00's Avatar
You probably blew the 7.5 amp fuse that gives power to the instrument cluster. The stereo shop that installed my new radio did that and they replaced the fuse and everything was fine. Just check underneath and look at the fuse box diagram and find the slot that says instrument panel or something like that.
Old May 13, 2002 | 01:37 PM
Thanks for the suggested, but unforunately that was not it... I tested the fuse and it is good... and other sugestions?
Old May 16, 2002 | 03:17 PM
I found out what did it... Blew the power outlet fuse all to pieces... The amp I have, I guess, is wired to it!
Tuan85
20
Jul 8, 2009 05:30 PM
ap2_lumpy
Mar 29, 2009 06:39 AM
s2kkyo
Nov 29, 2007 08:22 PM
captainbk
Apr 24, 2007 06:11 PM
S2KnJax
Feb 25, 2006 10:45 AM
