Keep blowing fuses
Old Feb 24, 2006 | 12:05 PM
S2KnJax's Avatar
Default Keep blowing fuses
About two days ago my amp quit working. The fuse under the hood was blown. I checked all connections and put in a new fuse. Blew instantly. I have now taken my car apart in hopes of finded a bare spot on either the remote or power wire and after checking both all the way back, I found nothing. Any idea of what else would blow a power fuse. Thanks in advance.
Old Feb 24, 2006 | 01:15 PM
boyguan's Avatar
amp is bad....
take out the power wire out of the amp
tape it up
see if it blows
that will tell you if it is the wire or the amp
Old Feb 24, 2006 | 01:20 PM
ASMspec's Avatar
Check your lighter socket and make sure there is no loose change in there then goto the amps and such. Good luck.
Old Feb 25, 2006 | 09:08 AM
S2KnJax's Avatar
Its not the amp. I just finished hooking it up in my other car and it works just fine. I dont know what else to do except rewire the whole thing.
Old Feb 25, 2006 | 09:36 AM
S2KnJax's Avatar
Now I just ran a power cable on the outside of the car to see if it was the power cable. When I started the car it popped the fuse. Then to check the remote wire i disconnected it and just jumped it from the power, still popped. Is there a chance that the fuse holder in the front of the car could be bad somehow. not sure how but maybe???
Old Feb 25, 2006 | 10:07 AM
S2KnJax's Avatar
Just changed to a different fuse holder. Still doesnt work. I have put amps in every car I have ever owned and never had a problem this confusing. Ive tried everything. A bad ground would just prevent the amp from turning on right, not pop fuses. THe ground wire is the only one I havent disconnected and changed, but the connection looks fine and the wire looks fine.
Old Feb 25, 2006 | 10:45 AM
boyguan's Avatar
is the fuse too small?
Blue_AP2
Jan 11, 2010 08:08 AM
ap2_lumpy
Mar 29, 2009 06:39 AM
s2kkyo
Nov 29, 2007 08:22 PM
formulaofsuccess
Sep 13, 2005 05:24 PM
LiQUiD iCE
Apr 12, 2005 06:20 AM
