proximity sensor..question
Old Apr 5, 2008 | 06:10 PM
tampas2000's Avatar
Default proximity sensor..question
i recently had an alarm installed on my car with proximity sensor.. i have noticed that it is way too sensitive.. if the sensor sees a shadow.. the alarm will go off... my question is.. what do you guys have the sensitivity set at... and how do you change the setting
Old Apr 6, 2008 | 01:15 PM
WLAURENT's Avatar
What prox sensor and where is it mounted (an how is it mounted).
Old Apr 6, 2008 | 02:31 PM
NFRS2K83's Avatar
Old Apr 6, 2008 | 02:51 PM
HankookS2K's Avatar
if its the 508d from dei, then you have two settings, an inner shield (alarm trigger) and an outer shield (warning trigger). On the unit there are two adjusting screws, one controls the inner and one controls the outer.
Old Apr 6, 2008 | 02:59 PM
WLAURENT's Avatar
Try this - http://www.darksidesubs.com/alarm/508D.PDF
Old Apr 6, 2008 | 03:04 PM
HankookS2K's Avatar
Originally Posted by WLAURENT,Apr 6 2008, 03:59 PM
there you go!
Old Apr 6, 2008 | 03:10 PM
00wreckedS's Avatar
i put mine in the top portion of the center console ( ie. secret compartment) and basically set the perimeters to prewarn within about 1.5-2 feet away, and then only full alarm when you reach inside, very easy to install
Old Apr 6, 2008 | 04:42 PM
tampas2000's Avatar
to be honest i just had it installed at an alarm place it is a viper 5002... i realy dont knw much about alarms .. or even where it is mounted.. i guess i should have found that info out b4 asking my question..
thanks guys ill try to find the sensor and look at the site
jwa4378
Dec 6, 2005 05:27 PM
moike
Apr 12, 2005 06:35 PM
GideonP
Jan 19, 2005 05:35 PM
sandman
Jun 11, 2004 05:22 AM
