Purchasing System, Just double checking
Looking forward to the pics! I took my new Sundown amp out this weekend and moved it around in the trunk, trying to get a sense of the potential fitment spots. I think I know what I'm going to do, but I'm still researching my options.
I must have missed it, but how did you wind up mounting your sub?
I know some of the corner boxes have like a metal tab that secures them, seems like they'd be mounted pretty solid.
What I do know is I want the sub in an easy to reach spot, that's quick and simple to remove it and the amp in a place with plenty of cooling that's also easy to access without any contortions.
Originally Posted by Jaeden09,Feb 9 2010, 12:49 PM
A metal tab? Care to elaborate?
Originally Posted by [DT
,Feb 9 2010, 04:34 PM] Any pics? I was thinking the same thing and as you know I have a 100.4 too. Seems like easy access, plenty of ventilation, etc., without making the cabling any more difficult.
Keep in mind that I'm short and have a Recaro SPG so I don't need all the space behind the driver/passenger seat. You'll lose 1-2 clicks on the stock seat.
My passenger (i.e., the Wifey©) will have to suffer
I'm about 6-1, but I don't drive with the seat all the way back.
Actually the passenger seat is pretty much the same place I always leave it, with a good 3-4" of space. I find the 2000 has a ton of foot room, especially on the passenger side.
I really appreciate the effort on the pics. I might take my amp down and check it out behind the seat just to get an idea.
I had some of those panels pulled out when I R&R'ed my center compartment, but I don't recall exactly what would be back there for an attachment point. I guess any kind of frame/rail/brace would be good[?]
This is extra interesting, because it means I could potentially run two amps without any space issues (and then go active with a dedicated sub amp).
,Feb 9 2010, 05:09 PM] My passenger (i.e., the Wifey©) will have to suffer
ExactlyRight now I just have my amps screwed to the body work back there. There's nothing behind (although I wouldn't go using a 3' drill bit either
) to hit when drilling so it's a pretty safe point.TBH, I don't really like having the amps mounted directly to the body, I'm working on an amp "rack" for each one that would allow me to more easily install/remove the amps for track days.
