Question on Installing an amp
Old Jun 28, 2012 | 05:57 PM
Kengthao91's Avatar
Default Question on Installing an amp
Alright sorry for being a noob at this audio stuff but yea, I'm installing an amp on my car and was wondering if i could use a different wattage wire... Ok i have a kenwood amp at 1000watt and couldn't find any wires for 1000 watt, instead all the stores i go to only have below 1200 watt wiring kit and above, so my question is, can i use a 1200watt amp wiring kit for my 1000watt amp? and can it damage my amp?... thanks for the suggestion
Old Jun 28, 2012 | 06:34 PM
S2KIrishman's Avatar
you might want to try the audio/electronics forum
Old Jun 28, 2012 | 06:40 PM
Kengthao91's Avatar
Thanks, just wanna see if anyone knew :/
Old Jun 28, 2012 | 07:34 PM
bmxer882x's Avatar
^ that is fine
Im running 6 gauge to my 4000 watt amp.
honestly i would ditch the kits and get everything seperate, works better imo
all you need is a rca which you can chose if you want gold plated or steel etc..
i would use 6 or 4 gauge wire for your powerwire
and i have 12 gauge as my remote. then a short 4 gauge for my ground.
Old Jun 29, 2012 | 04:39 AM
takeshi's Avatar
You can do that in the electronics subforum. Don't post in the wrong subforum for traffic reasons.
Old Jun 29, 2012 | 08:21 AM
Manga_Spawn's Avatar
Site Moderator
6 gauge is way to small and if you ever upgrade then you need to redo the wiring. Just start with 4 gauge for the power and ground wires for the amp. The wattage ratings on the wiring kits don't really mean anything. The more power you are trying to push the bigger the wire needs to be.
Old Jun 29, 2012 | 10:31 AM
Toms1989's Avatar
Is this RMS figures or some Max figure? If the latter, ignore that... probably more like 200-300 watts RMS, if so an 8 gauge kit would suffice.
MoeTE87
May 17, 2010 05:36 AM
sscott0203
Oct 20, 2005 10:53 PM
SilverstoneS2k_FL
Feb 18, 2005 08:21 AM
Josh and Jenny
Nov 24, 2002 06:29 PM
djkojione
Nov 5, 2002 12:37 PM
