Radar Detector Power
Old Apr 30, 2001 | 08:18 PM
Hombre's Avatar
I know this may seem overly simplistic but... I got a Passport Solo. It works just as well as my Passport 8500, and is cordless. That's it! $199 and no cord, no hard wiring. Problem solved.
Old May 1, 2001 | 07:51 AM
Yellow S2000's Avatar
[QUOTE] Originally posted by justification
Any further suggestions for this type of installation? This seems far simpler then running the wire down the A-frame? Are there any down sides?
Old May 1, 2001 | 08:09 PM
Utah S2K's Avatar
....er ah, might want to check the specs on those two detectors you say are equivalent Hombre . Contact Cincinatti Microwave, they made them both which are distributed by Escort.
Old May 2, 2001 | 06:17 PM
justification's Avatar
[QUOTE]Originally posted by Yellow S2000
[B][QUOTE] Originally posted by justification
Old May 2, 2001 | 08:01 PM
I will post pictures of the install if you want.. Let me know
Side View
Front View
Old May 3, 2001 | 08:57 AM
Thanks for all the help. This forum is awesome and the people are wicked helpful. I've watched other roadster forums and none of them compare to this.
I have not received the V1 yet. When I do if I need some more help then I'll bother you for the installation pics.
Thanks again.
Old May 3, 2001 | 01:03 PM
stook29k's Avatar
I use the passenger side visor and skip the V1 fuse link. Much neater inmho.Just pry off the lens,wrap the hot lead around the end of the bulb,connect the ground on one of the screws and snap the lens back on crimping the wire. No cutting or splicing required.
[Edited by stook29k on 05-04-2001 at 07:01 AM]
Old May 3, 2001 | 08:37 PM
Goldtrom's Avatar
Yellow s2000,
How did you get into the dome light? Did you drill a hole? Please, don't say you drilled a hole... I really want to wire it the same way, but don't think I'm up to drilling my baby.
Old May 4, 2001 | 07:07 AM
No holes were drilled Just pry off the lens, unscrew the screws & the light will come out.. You will see were you can feed the wires up from the back trim.. I then spliced into the blue/white wire for 12V & connected the ground on one of the screws & put the lens cover back on..
it'S2klean
Jan 20, 2011 01:55 PM
AllenS2K
May 18, 2007 10:33 PM
dmw16
Jun 26, 2006 11:22 AM
basslover911
Mar 28, 2006 04:15 PM
