Radio help
I assume you mean you have the modifry DCI?
If so, it depends on which version DCI you have. If it's a wired DCI then at best it will work on Sony and Pioneer, assuming of course that the HU has an input for a wired remote.
If you have the IR DCI then you'll have to check the label on the DCI module to see which HU brands are supported. If it's IR and you bought it after Jan 2006 then it will do 10 different HU. Earlier versions only did 3 or 4 HU.
On the other hand if you're really just asking about the harness then the answer is it can be used with any HU.
S2PIDSTYLE
Aug 2, 2008 01:55 AM
