Rear Speakers
Old Nov 22, 2008 | 08:21 PM
esmith51's Avatar
Default Rear Speakers
I read that Lucid no longer sells the panels for the rear speaker install. I was wonderin how difficult it is to mount rear speakers in that panel and what size/dimension speakers would fit. I was considering putting a set of Alpine Type-R two-way speakers (identical to the ones I installed in the front), if they would fit. I searched through the threads and was unable to find any definative information about the install. Any information about this type of install would be greatly appreciated.
Old Nov 22, 2008 | 11:07 PM
FireF4ly's Avatar
I was able to install the polk db6500's in my 2003 without having to "trim" the metal behind it, but it took a lot of trial and error before I got it just right. If/when I were to do it again I will definately use 5.25's behind the seats in those panels.
As far as the walkthrouh's go for cutting and installing the speakers in those panels just plan on spending $25 for a new panel behind the seats. I found it was easiest to just cut and shape one panel to my needed specs; then transfer the dimensions over to the new/opposite side panel. What's another $25 when you spend 200+ on speakers
Old Nov 23, 2008 | 03:05 PM
esmith51's Avatar
I'll definately spend $25 on another set of panels. I was just tryign to find out if anyone had a set of the lucid panels laying around or a diagram of what to cut. I was also very intersted in the actual dimesions that would fit in the spot for determining fitment in purchasing a speaker. Any information would be greatly appreciated.
mattrh615
Nov 19, 2010 09:51 AM
suprfunguy
Jan 13, 2006 06:16 AM
Wahooz
Dec 21, 2005 02:41 PM
Bass
Feb 16, 2004 02:34 AM
jcoates1
Feb 7, 2002 02:08 PM
