Remote Keyless No Longer Works!
Old Dec 30, 2013 | 03:49 PM
Spectre48's Avatar
Default Remote Keyless No Longer Works!
Hey,
I have a MY2002, and my keyless entry no longer works. It has the factory installed alarm system as well.
This summer, it began to increasingly act up. At first, it would take a few pushes of the button, then 5 minutes, and now it won't work at all.
After hours of searching, I tried:
- Replacing batteries. Both fobs. The LED does light up on both.
- Reprogramming both fobs to the car. The solenoid in the door does make a noise to tell me they are connected. However, they do not lock/unlock after that!
- Pulling the 15 amp fuse for keyless, as well as the two 3 amp fuses that go with the alarm system. Some people have had luck with this. I didn't.
- General checking of electrical connections, nothing obvious.
Please help. Any ideas?
Thanks, Jeff
Old Jan 6, 2014 | 07:55 AM
modifry's Avatar
Honorary Member
Check your door switches to make sure they are working correctly, I don't think the keyless will lock the doors if it thinks one of them is open. Since it's tied into the alarm system, a bad hood or trunk sensor might cause the same problem.
JermDorson
Feb 5, 2016 08:34 PM
yorkies2k
May 12, 2014 02:36 PM
vstypicals
Mar 6, 2011 06:10 PM
Matt15
Aug 30, 2010 07:03 PM
JLUDE
Aug 28, 2009 09:46 PM
