Removing Roof well
Old Jan 13, 2002 | 01:23 PM
Black2k2's Avatar
Default Removing Roof well
Okay, I've been fiddling with this dang thing for the past day, and cant figure out how to remove the plastic roof well to let more bass into the cabin. I've removed all the fasteners from the inside, and have removed the couple from the trunk. But can't seem to get the dang thing out. (I'm not using any force to remove it.)
My questions are:
1. DO you remove it by pulling from the inside? or by pushing up from the trunk?
2. DOES it require a lot of force (I'm afraid of breaking things)
3. IS there any easy way to remove it.
Any help is appreciated.
Thanks
Old Jan 13, 2002 | 01:56 PM
moyopoyo's Avatar
i think "what the" did it for the same reason. try PMing him and see how it works out.
Old Jan 13, 2002 | 09:24 PM
dkhl's Avatar
what would the purpose be? the only reason might be to get extra space for say bigger speakers or amps... i might do it if it is easy...
Old Jan 14, 2002 | 08:16 AM
Colombino's Avatar
I removed my roof well to allow the bass to flow better and to get rid of some rattling. Go back and make sure that all of the fasteners are removed. Don't forget that you are going to have to remove the back panel as well as the roof well (or at least before). You shouldn't have to force anything after you take off all the fasteners. Tug on it gently and get an idea of where it's still attached.
Hope this helps.
Old Jan 14, 2002 | 11:37 AM
DouglaS2000's Avatar
I popped mine out and it was a pain in the @ss. It's not 1 piece. There are 2 pieces. The tub itself and the strip that lines the bottom of the window. First, you have to tug on that strip, it should snap off. Then, from inside the trunk, look for the white clips, use a needlenose plier to push them up. Then, from the inside of the car, pull the tub up. This may take some force to do.
Old Jan 14, 2002 | 10:02 PM
Black2k2's Avatar
Douglas2000-
Awesome advice!!! I finally got the thing out. I pulled that strip off first. Then I ended up pulling the well through the trunk (with a little bending and maneuvering) Now that I know how, it shouldn't take too long. BUT DAMM did it take a long time to figure out
Old Jan 14, 2002 | 10:03 PM
Black2k2's Avatar
I forgot to ask. What did you put in place of the well? Did you leave it uncovered, or did you put some kind of fabric over it? I kind of don't like the fact that you can see into the trunk.
Old Jan 15, 2002 | 06:02 AM
I just used the carpeting they sold for sub enclosures to cover that area.
alens2k
Apr 20, 2025 07:23 AM
garettb16
Dec 26, 2010 05:33 PM
deanjones
Jul 19, 2005 05:33 PM
pikkashoe
Dec 21, 2004 07:00 PM
FoxMan
Aug 14, 2004 01:26 PM
