Replace dashboard light bulb?
Old Mar 5, 2007 | 10:04 AM
s2kav6's Avatar
Default Replace dashboard light bulb?
Does anyone know how to replace the light bulb behind the dashboard? The one behind behind the different venting modes fail but I don't know how to get behind and replace it..
thx in advance
Old Mar 7, 2007 | 08:29 AM
s2kav6's Avatar
no one know??
Old Mar 13, 2007 | 12:36 AM
r_duff's Avatar
hey. Im not sure where to get the bulb. probably honda dealer will have to order it for you.
To get to it is a pain in the ass. You have to:
1. remove lower steeringwheel cover (3 phillips head)
2. remove 2 nuts that hold the steering column up nearest the steering wheel (12mm)
3. loosen the 2 nuts right above the foot vent (12mm) about half way
4. Remove the to caps on the Cluster hood and remove 2 phillips screws
5. pull down steering wheel. remove the upper column cover.
6. while steeringwheel and column are down, pull out the entire dash bezel (held by clips only). use a taped flat screwdriver or fingernails and work your way out. manuver it around the column and signal/wiper stalks.
7. while doing this, you have to reach behind and disconnect stuff as you go along. the starter button, radio controls, hvac controls, crusie control, defroster, all have a plug.
8. remove the 3 phillips screws that hold the HVAC controls in the bezel. remove HVAC unit.
9. locate which bulb is out (should be one of the white bases IIRC. looks kinda like a button with a slit in it). To remove the bulb, use a small flathead screwdriver and turn the base 1/4 turn counterclockwise and pull it straight out.
have fun!
Old Mar 13, 2007 | 02:19 AM
Suzukuh's Avatar
^ just had to do the same thing. I was finished in about an hour. You can get around all of the wiring harness, just take your time and move yourself around a bit to reach all of the bolts. Enjoy.
HighwayStar
May 15, 2010 10:41 AM
S2Kyle01
Mar 4, 2007 07:51 PM
Suzukuh
Feb 23, 2007 11:35 AM
anthonys2k
Nov 22, 2004 01:09 PM
aznhomie
Feb 18, 2004 07:21 PM
