Engine Start button and Radio dash controls
Old Nov 16, 2004 | 05:52 PM
anthonys2k's Avatar
Default Engine Start button and Radio dash controls
One of the bulbs went out under the "ch" button and i have the bulb on the way from honda, and i got the diagram and it looks like the screws are in from the back?..how can i get to it to replace the bulb underneath?
Old Nov 16, 2004 | 09:26 PM
Venomous S's Avatar
All the bulbs for the dash controls are in the back of the instrument panel. You have to take the cover off the dash by removing the 2 caps on the top of the inside of the dash, then you have to remove the 2 screws in there, then pry the cover off carefully. If you need more clearance which I did as I was doing other things, then you have to remove the steering column cover and drop down the steering column by removing the 2 nuts that hold it up.
In the back of the panel you will see holes and inside you will see kinda like a around white thing with a slot in the middle. Those are the bubls. Just find the right one and turn it counterclockwise and take it out. Turn clockwise to screw back on...
Old Nov 17, 2004 | 12:23 AM
dut's Avatar
dut
- its not too fun since the steering wheel can only be moved about an inch or two down...
Old Nov 17, 2004 | 03:29 AM
Venomous S's Avatar
Its not complicated at all. You dont have to take the cover completely off to replace the bulbs if you use a small flat-tip screwdriver.
Old Nov 22, 2004 | 01:09 PM
anthonys2k's Avatar
thanks for the advice..hopefully i can get around to doing it this week
Adam.B
Dec 24, 2011 07:41 AM
s2konroids
Jul 31, 2011 09:38 PM
kimbo305
May 23, 2010 01:44 PM
spdlmtna
Feb 5, 2007 09:47 PM
KenS2K
Jul 11, 2001 12:30 PM
