Roady 2 headunit...where did you put it?
Old Sep 12, 2004 | 01:46 PM
JNT Handyman's Avatar
Default Roady 2 headunit...where did you put it?
Where did you mount the actual head unit of your XM radio? There are plenty of surfaces to choose from, but I want something that will be relatively clean in case I ever decide to get rid of the radio.
Thanks,
JNT Handyman
Old Sep 12, 2004 | 07:11 PM
steven975's Avatar
I have a roady1, but it's essentially the same.
You know the bracket that goes on back? I trimmed the bottom a little to make it easier to remove from the unit. I stuck that bracket to the radio door with some tape and it works well. the door opens enough to pull CDs, too. I also used a wired FM modulator which comes with a 6VDC out, meaining you don't need the lighter socket. Everything is behind the dash with the 3 wires coming out under the door.
ezekielguy86
Jul 26, 2014 03:52 PM
starrman
May 24, 2011 12:43 PM
hook3549
Dec 20, 2010 06:11 AM
s2kxier
Nov 23, 2006 05:59 AM
LubedKoala
Oct 29, 2005 10:00 PM
