Satellite Radio
Old Dec 26, 2004 | 04:39 PM
NECurve's Avatar
Default Satellite Radio
Anyone here install an aftermarket Satellite Radio unit WITHOUT replacing the cars head unit?
Where did you put it?
I purchased a Sirius unit, I think it is much better than XM, and I want to keep the car looking stock at first glance. Any ideas? Pics?
I was thinking of using the "cup holder" since I don't carry drinks in my car anyway.
Thanks for any help!
Old Dec 27, 2004 | 07:25 AM
Andy Kirk's Avatar
Hi: Here is the location I used for my XM control head. I did replace the HU as I wanted to be able to listen to CDs I burned in MP3 format and also have more power to the speakers The mount is available from Crutchfield for about $25 and con be removed from the car with out much trace, just 3 holes in a piece of plastic. If you do use this method do not rely on the glue as it soon will give up.
https://www.s2ki.com/forums/index.php?act=m...lbum&album=4010
I installed the CD changer under the seat and the antenna in the secret compartment. The plastic cover does not inhibit reception and t he convertable top is transparent to the signal.
Andy
Andy Kirk's Avatar
Andy
Old Dec 27, 2004 | 10:34 AM
flitcroft's Avatar
I just installed XM in my mom's Mazda3 yesterday I have seen people mount V1 displays and VTEC controllers in the cup holder so you could probably make it work with a fair amount of cutting. Which controller did you buy? What are the dimensions?
I gotta say I went with XM partailly because the units and antennas were smaller. My install was with a Delphi Skyfi 2 and little antenna pod thing was a breeze to mount on the dash (and it gets full signal there too -- score!)
Old Dec 27, 2004 | 11:06 AM
darkknight1999's Avatar
It would be so easy to mold that right into the sunvisor. Kinda like the way my VAF-C is molded. It would be mostly out of the way and it would keep your car looking completely stock from the outside.
This is what it would look like:
I had the visor rewrapped in black vinyl to hide the wires. Then I dremeled out around the visor pivot on the left hand side and ran the wiring down the a-piller.
Kmad86
Sep 30, 2016 02:19 PM
DJT
May 23, 2010 12:52 PM
xrapidx
Jul 24, 2008 06:57 AM
MintyWinty
Jan 1, 2003 04:37 PM
