scangauge II problem
Old Oct 26, 2008 | 10:40 AM
RichV's Avatar
Default scangauge II problem
Hey guys,
I bought a scangauge II a couple weeks ago and everything is working great but the mph reading.
Only problem I am having with my scanguage is the mph gauge tops out at 42mph !! I have tried changing and calibrating everything I could, but it still reads tops at 42 mph. It is correct all the way up until I get to 42 mph (reads the same as my speedometer) then just stays at 42.
My speedo reads correct speed, so I don't understand this. Anyone have any ideas?
Old Oct 26, 2008 | 01:13 PM
darkknight1999's Avatar
Sounds broken
Old Oct 26, 2008 | 01:18 PM
G's Avatar
G
Mine will show far higher than the 42 you are seeing. I agree if it is new contact the company to see if they can tell you how to fix it, or send it back.
Old Oct 26, 2008 | 07:08 PM
RichV's Avatar
I finally got ahold of someone in customer service and they are shipping me out a new replacement. They were very nice and helpful. Hopefully that will fix the problem.
Old Oct 30, 2008 | 06:09 PM
RichV's Avatar
I received my new Scangauge today, but it does the same thing. It must be a false reading coming from the OBD2 plug. How do you fix that??
Old Oct 30, 2008 | 07:57 PM
G's Avatar
G
how fast do you have the refreshing set for?
I read somewhere that it tends to get more errors when it is trying to update too fast.
Old Oct 31, 2008 | 04:34 AM
RichV's Avatar
It was set to fast, but I changed it to normal. Slow is just too damn slow! Everything worked for me on fast, but I changed it to normal to try to fix this. It's really weird. It reads spot on, same as my speedo, until 42 than stops. Can't be a scanguage problem, because I have tried two different ones.
Old Nov 6, 2008 | 09:55 AM
SC_Highlander's Avatar
That's wacky. I have one that I swap between my truck and my S and have never had the problem you describe.
onara77
Apr 27, 2012 02:38 AM
bj84
Apr 7, 2009 05:59 AM
124Spider
Oct 19, 2005 05:17 PM
Dark_Sub_Rosa
May 12, 2005 06:04 PM
astage
Aug 30, 2002 11:49 AM
