Size of door speakers
Old May 4, 2004 | 07:26 AM
Skeptik's Avatar
Default Size of door speakers
I searched the FAQ and MacGuyver's site and found all sorts of information except what the stock speaker size in the doors are. I am assuming it is 6.5". Is this correct?
Old May 4, 2004 | 08:09 AM
jedraz's Avatar
Yes. 6.5
Old May 4, 2004 | 09:13 AM
natedoggs2k's Avatar
I usually recommend 5.25" for best fit and least amount of alteration to door and speaker mount. I don't like to do much cutting/modifications to the car. I want it to be as stock as possible with a perfect fit.
I've run 5.25" MB Quarts in various cars (Honda CRX Si, WRX, Type R), and they were perfect. They fit well and sound good (as long as you have a good amp).
Old May 4, 2004 | 10:06 AM
Willie Gee's Avatar
6.5 is stock-a-roni
Old May 4, 2004 | 10:51 AM
NFRs2000NYC's Avatar
Nate...you are 100% wrong on this....
Putting 5.25 speakers in an s2k is MORE work than putting in 6.5s The stock mounting is made for 6.5, so dont go smaller.
Old May 4, 2004 | 11:15 AM
Skeptik's Avatar
Thanks for the 411
Old May 4, 2004 | 11:24 AM
Well, maybe it depends on the speaker, as my MB Quarts mounted PERFECTLY to the stock speaker mounts. No additional drilling of the doors. Only had to cut the back of the mount so they could accommodate the depth of the MB Quarts.
Obviously, you want to go as large as possible in the stock location (6.5"), but sometimes, going smaller can be fine depending on the speaker and its size for mounting.
Old May 4, 2004 | 08:59 PM
JP_BLACK's Avatar
hi, just came across this thread and remember reading on here that the 04 model speaker size is smaller. I was curious cause i was builing a system also.
Old May 5, 2004 | 08:28 AM
jocko2's Avatar
MY04 are NOT smaller. Stock size is 6.5".
Old May 5, 2004 | 11:38 AM
JP_BLACK's Avatar
ok thanks!
dsthez
Dec 6, 2012 10:29 PM
RaceyR6
Mar 23, 2006 01:46 PM
jwa4378
Jun 17, 2005 05:06 AM
JRT
Apr 6, 2004 07:31 AM
h0ckeypunk
Mar 5, 2004 08:37 PM
