Some pictures of the new system...work in progress ;)
Old Mar 2, 2004 | 03:38 PM
  #61
ideugene's Avatar
*taking notes* one day... i will have a system like this... after i mess up... ill be calling you to help me cover my mistakes
Old Mar 2, 2004 | 05:26 PM
  #62
darkknight1999's Avatar
You'll be fine measure 3 times / cut once
Old Mar 2, 2004 | 06:29 PM
  #63
FF2Skip's Avatar
How do I cut the body filler? (fingers still sore from sanding w/ 36 grit!)
Old Mar 2, 2004 | 06:34 PM
  #64
an air sander the whole process might take you 30minutes
Old Mar 2, 2004 | 06:38 PM
  #65
Willie Gee's Avatar
an air sander
& a really good respirator
Old Mar 2, 2004 | 06:46 PM
  #66
and that's a really good point
Old Mar 3, 2004 | 12:43 AM
  #67
Squeezer's Avatar
how did you cut the inside lip on the round mdf cutout that the port tube and subwoofer rest on?
Old Mar 3, 2004 | 04:03 AM
  #68
With a routing table, using a rabbet bit with a......3/4inch bearing on it.
Old Mar 3, 2004 | 09:57 AM
  #69
Squeezer's Avatar
cool, i also found this way to make the ring around the sub, I think i'll do it this way even though it won't look as nice cause its easier
http://web.njit.edu/~cas1383/mdf%20rings/
Old Mar 3, 2004 | 01:59 PM
  #70
Actually the router is way easier than that....
With the router you make the ring size with a pen, router the outside, so now you have a circle. Drill a second hole on the inside and router that out. So now you have a ring. Then just switch bits to the rabbet and go around the inside and you done...
There's a little more than that to it but that's the jest of it.
