Speaker Buzz with Enginer RPM
Old Mar 12, 2004 | 05:03 PM
Lunacy's Avatar
Default Speaker Buzz with Enginer RPM
My speaker buzzes and the buzz varies with engine RPM.
could this be caused by speaker wires too close to the power wires of the AMP?
any other possible causes?
Old Mar 12, 2004 | 05:07 PM
YOD88's Avatar
which speakers are they?
vibration from the engine and car moving on the ground could be affecting it... just a thought
Old Mar 12, 2004 | 05:26 PM
SeaDoXPL's Avatar
Power wires should be run on one side and the RCA cables should be on the other.
Thats just for starters.
Do a search on engine noise.
I'm sure this subject has been talked to death.
I know I chimed in on a few threads.
Oh Here is one I found.
http://forums.s2ki.com/forums/showthread.p...25&pagenumber=1
When "McGyver" and "Modifry" chime in , you know you are getting some good advice.
Old Mar 13, 2004 | 10:02 AM
PJK3's Avatar
if don't already have your RCA's away from the power, then move those...
then, check, check, and double check your grounds.
if that doesn't fix it... bump this thread...
Old Mar 13, 2004 | 10:15 AM
NFRs2000NYC's Avatar
[QUOTE]Originally posted by PJK3
Old Mar 13, 2004 | 09:31 PM
Lunacy's Avatar
Old Mar 13, 2004 | 09:44 PM
A stock honda ground. ITs got a gold bolt with a lot of little black wires coming out of it. in the trunk, if you take off the two vertical panels (spare tire bulge and the other one,) it should be in the middle up top I believe.
Old Mar 14, 2004 | 09:16 AM
PJK3's Avatar
Honda's grounds are good... i've also used this ground myself (as have others) to much success....
Grounding off of brace bolt
Old Mar 15, 2004 | 12:53 PM
Kronos's Avatar
I have found that 1 ground on Brace bolt is fine...but I have a problem when grounding 2 amps to same. I am getting a grounding block today to see if that helps.
Old Mar 15, 2004 | 06:40 PM
Hickey322's Avatar
i just had problems grounding 2 amps to the same point. i get a high pitched whine thats rpm sensative. i grounded the amps in different places and no more whine.
