Speaker wire question
Old Jun 23, 2001 | 04:38 PM
S2R's Avatar
S2R
Default Speaker wire question
I changed the head unit and plugged in some aftermarket speakers. Is it necessary to change the speaker wire? What if you add an amp, do you have to change the speaker wire then? I'll change the wires if I have to, but shoot I'm trying to avoid it cuz it looks like a lot of work to put in.
Old Jun 23, 2001 | 06:26 PM
01Silver's Avatar
spend the time and replace the wires.
mark
Old Jun 23, 2001 | 06:40 PM
Barry in Wyoming's Avatar
I just "upgraded" from Honda's wiring to Fosgate 16 gauge speaker wire. It took me four hours, was a lot of "fun" and challenging.
I think the system sounds exactly the same, no better no worse.
My head is an Alpine CDA-7876 putting out 27 watts rms/channel , "60 watts x 4" peak.
Unless you have an amp and component speakers, I really doubt the new speaker wire will get you anything. However, you won't know until you try.
See this thread for more comments on the same.
http://www.s2000online.com/forums/showthre...?threadid=17258
Old Jun 23, 2001 | 07:47 PM
lucid's Avatar
You only need to change the wire really if you add an amp. You should be ok if you just change you speakers and/or head unit.
Old Jun 23, 2001 | 08:10 PM
S2R's Avatar
S2R
I'm going to suck it up and work it. I got the 15 awg flat Rockford Fosgate wires. I wonder if those are harder to install than the standard round wires?
Old Jun 23, 2001 | 11:19 PM
jerrypeterson's Avatar
Get the round. I am in the middle of my install and just finished my doors this afternoon. Don't even try using the flatwire speaker cables. You would be fine until you tried routing the wire thru the door junction. With the flat wire when you get to the door, you might as well grab your ankles.
Old Jun 23, 2001 | 11:46 PM
DSF_S2k's Avatar
I just upgraded the speakers and added an amp. Used the stock wires from the head unit. Ran 2 sets of speaker wires to the back. One for the input to the amp from the factory head, the other from the amp to the head, which I tapped to the front speakers. speakers sound great, didn't want to bother trying to feed the new wire's through the door. It's a real pain in the a$$.
Old Jun 24, 2001 | 12:18 AM
ceworkman's Avatar
There is no need to upgrade the speaker wire in the car. The only thing to keep in mind is that you might want to leave the factory plug in case you ever want to put the factory ones back in. There should be no difference in sound and plus, running the new ones through the boot in the door is a pain in the $%&. If you decide to run new wires, I suggest using a large zip tie to go through the boot to keep from tearing it or poking other wires.
Old Jun 24, 2001 | 09:30 AM
S2R's Avatar
S2R
I've got an 75x2 amp for my speakers, so it's okay to leave the stock wiring? Cuz that would be awesome if I didn't have to go through the trouble.
Old Jun 24, 2001 | 07:09 PM
ceworkman's Avatar
There should not be any problem with leaving what is in the door but you will have to run new wire to the amp of course and sometimes people opt to do new wire to the speakers also. You can cut the wires close (but not too close) to the factory radio plug and make your connections there to go back to the amp. Either way, you can leave the wire in the doors without a problem. Plus, you don
EscapePod
May 4, 2018 02:46 PM
dlpowered89
Feb 12, 2015 09:41 AM
DangerZone9K
Mar 4, 2011 05:31 AM
Forrest2b
Jul 7, 2001 04:18 PM
Y2K++S2K
May 3, 2001 07:10 PM
