Stereo swap and keep dash controls
Old Jul 11, 2001 | 07:29 AM
Gunfighter73's Avatar
Default Stereo swap and keep dash controls
So what is the definative way of installing a new stereo but still keeping your dash conrols. I have read the links about the remote and about the various hardwire possibilities, but I'm still confused. Has anyone developed a true plug and play adaptor? I am leaning towards the Alpine's. If you use the remote LED transmitter option, do you have to leave the stereo door open?
Thanks for the help
Old Jul 11, 2001 | 09:28 AM
Yellow S2000's Avatar
No you do not need to leave the door open.. Here is a picture of my PAC SWI-3 (LED transmitter) Do you you see the LED..
Old Jul 11, 2001 | 10:19 AM
marcucci's Avatar
I'm in the process of doing this electrically (w/o the optical interface). This is only possible on head units that use wired remotes (like Sony units that use joysticks). The factory controls use a matrix of resistors to place a resistance between the remote wire and ground; this happens to be the same way the Sony units work. As soon as I get the controls out, I'll be reworking the PCB to generate the Sony-compatible resistance values. VERY easy mod for someone with basic electronics experience that can solder.
Old Jul 11, 2001 | 06:54 PM
vegas005's Avatar
marcucci,
I would be very interested in hearing from you when you finish this solution. It sounds like the best way to go!
Old Jul 13, 2001 | 10:11 AM
marcucci's Avatar
Originally posted by vegas005
marcucci,
PM or email me, I can keep you up to date. If you have a Sony with the joystick, it should be identical. For any other make, it would have to have a wired remote and even then, I'm not sure it would be doable.
My mod involves either changing the resistors currently on the stock control PC board or soldering additional resistors in parallel to drop the R values. Either way, with a little soldering experience, it's a fairly easy fix.
modestgod
Mar 31, 2010 05:45 PM
REV IT
Jun 11, 2003 08:27 PM
Aaw Dude
May 13, 2002 11:58 AM
amartin
Jan 23, 2002 11:37 AM
drogers
Aug 25, 2001 03:42 PM
