Strange problem with audio controls
Old Feb 16, 2004 | 09:31 PM
MidnightSi's Avatar
Default Strange problem with audio controls
Three days ago my audio controls (the controls on the left side of the wheel) started to act funny. Half the time I press the volume down button the channel will change. Other times I will press the mode button and the volume will change. My car is a bone stock MY2000. All of the radio knobs and buttons work as usual. I'm wondering if anyone else has encountered this?
Old Feb 17, 2004 | 01:58 PM
jeffbrig's Avatar
The dash switches are tied to a resistor network that's part of a voltage divider circuit. The voltage output from this circuit is connected to the head unit, which reads the level and determines which button has been pressed. Obviously, the voltage on this line is out of whack. It could be a problem/short in the dash control circuit, a bad A/D channel in the head unit reading that voltage level, a general battery/alternator voltage problem, or a bad ground at any point in between.
Old Feb 17, 2004 | 02:13 PM
shortbloke's Avatar
I also had this, but mine was due to the 3.5mm jack plug from my Alpine Dash Interface KCE-965B not being fully inserted into the HU Alpine 9815.
Might be worth checking (if you have something similar)
Old Feb 17, 2004 | 02:14 PM
shortbloke's Avatar
Opps just re-read your still using stock equipment, so ignore what I just said.
Its too late - time to go to sleep
Old Feb 17, 2004 | 05:18 PM
MidnightSi's Avatar
Thanks for the suggestions. When I get a chance I'm going to pull the head unit to check for a loose connection.
eSeM
Jul 11, 2012 10:12 AM
RevRanger
Jun 26, 2012 01:50 AM
gambit-irl
May 16, 2012 12:13 PM
BigTed
Apr 1, 2003 12:26 PM
92068320
Mar 6, 2003 12:56 AM
