Sub itself rattles?
Old Aug 3, 2007 | 03:06 PM
DDuds2k's Avatar
Default Sub itself rattles?
So Ive been looking to locate where the rattle is coming from. Come to notice, the sub itself has a rattle to it. Similar in sound to what normal trunk rattles sound like. Could this be b/c the box is too small and does not allow the sub to hit cleanly or is this a sign of damage?
Old Aug 4, 2007 | 06:35 AM
Grimey's Avatar
Are you sure that it's the sub rattling and not the box? It's pretty unusual but not impossible for the sub to rattle. If the sub it rattling, that usually denotes a problem with the sub.
Old Aug 4, 2007 | 08:32 AM
DDuds2k's Avatar
It sort of sounds liek the sub is working too hard, but I think this may be true since the sub is in a box that is too small. But, since the sub and box are attached to eachother, I cannot distinguish if it is the sub making the rattle or the box. It is coming from the front though...so its either the sub, or the box ring. not sure.
Old Aug 4, 2007 | 12:35 PM
jwa4378's Avatar
Are you hearing the speaker cone bottoming out on the voice coil?! The box could rattle if it was not glued properly... but it would be more of a squeaky rattle. How well is the sub secured?
John
Old Aug 4, 2007 | 02:17 PM
DDuds2k's Avatar
The box is a very tight fit, and I was unable to get the sub screwed down "perfectly" But it is a very tight fit. What doyou mean by "bottoming out" ? Never heard that term. Is that do to improper securing?
Old Aug 5, 2007 | 07:56 AM
jwa4378's Avatar
Its due to overpowering the sub. It will sound more like a "whack" than a "rattle". This is how you can fry your voice coils... I think you would know it if you heard it. Does it only happen at high volumes?
John
Old Aug 6, 2007 | 08:52 PM
DDuds2k's Avatar
John
I think you're right. I have a 600x1 alpine mrp-m650, if figured it probably doesnt put out 600 since amps rarely do what they say...so im thinking 500+ area. with a w6, optimal at 400, danger over 500. I turned the gain all the way down- no more rattle. But, I havent really pushed it either. Is turning the gain down enough to protect this sub, or should i sell the amp and get a 500 watt JL?
mpease0603
Oct 9, 2008 08:05 AM
plutonium239
Aug 20, 2007 01:47 PM
steve summers
Oct 17, 2006 01:33 PM
sleeze
Dec 26, 2005 08:08 AM
JAPCAB
Nov 22, 2005 07:16 AM
