Which sub should I get for Wlaurent's sub box?
Old Aug 17, 2004 | 11:19 AM
Fusiondynamics's Avatar
Default Which sub should I get for Wlaurent's sub box?
I'm deciding between three:
Rockford He2
Rockford Punch 2
Polk Momo
Or is there something better I should use. I have a old amp that will run 150w rms at 4 ohm bridged.
My budget for the sub is about 150 bucks max.
Old Aug 17, 2004 | 11:42 AM
Icemn2003's Avatar
you may look into this one, it's the one I have, but I'm feeding 300W RMS, but it is an amazing little sub, and not too well used here since the e8a went away.
http://www.alphasonik.com/600Subs.html
the 608 is the 8 in.
Old Aug 17, 2004 | 12:14 PM
That def. looks nice! I noticed that it is a DVC sub at 4 ohms. When you hook it up as a single sub. Won't it run at 2 ohms or is there a way to run it at 4 ohms. My amp is only stable up to 75 w at 2 ohms and 150 w at 4 ohms.
I don't know too much about wiring and from all the wiring diagrams I saw, it shows (Rockford's and JL's site):
8 ohms dvc = wired to 4 ohms
4 ohms dvc = wired to 2 ohms
2 ohms dvc = wired to 1 ohm
Thanks!
Kham
PS. How much did you pay??
Old Aug 17, 2004 | 12:42 PM
D-04's Avatar
You are correct, this sub can only be run at 2 or 8 ohms, neither being suitable for you.
You might also want to check out the Eclipse 8". They make a 4 ohm model but I am not sure if it's under the $150 mark.
Old Aug 18, 2004 | 06:42 PM
efthimios's Avatar
I'm running 8" L7's in Wlaurent boxes and they POUND
Old Aug 19, 2004 | 10:32 AM
Thanks for your responses!
I ended up going with the Rockford Punch 2.
I really wanted to get the Alphasonik, but I didn't want to buy another amp to run it. (It sucked cuz I have 3 amps laying around and none could run 2 ohms)
T-Smac
Sep 11, 2011 11:37 PM
4bang6
Jun 14, 2007 09:36 PM
Brutewes
May 16, 2006 01:14 PM
ruexp67
Jun 13, 2005 08:57 AM
pikkashoe
Sep 2, 2004 03:20 PM
