sub wiring: need help
Old Jun 14, 2007 | 11:28 AM
4bang6's Avatar
Default sub wiring: need help
I have two dual voice coil subs to run off one bridged amp......any suggestions on where to find a wiring diagram would be helpful....thanks
Old Jun 14, 2007 | 11:41 AM
imdarkrider's Avatar
how many Ohms per coil , and what ohm will the amp play at?
Old Jun 14, 2007 | 01:06 PM
S2KinVA's Avatar
^^ What he said.
Old Jun 14, 2007 | 01:21 PM
4bang6's Avatar
Amp is a punch 80, not sure if it(amp) is 1ohm stable or not but the subs are 4ohm per speaker,does not say if it is per coil...... just got this stuff from a friend, I do have other amps if this one is not enough.
Old Jun 14, 2007 | 02:16 PM
really gotta know this stuff or you'll blow your amp....
I doubt it's 1 ohm stable so your going to have to run it at 4 ohms if it's a dual 4 ohm sub...
take positive of one side of the sub and run it to the negative of the same sub (sounds like it'll blow but it won't) this will make the other coild in the sub 8 ohms... do the same to the other sub , now run the positive and negative of each sub to the amp and your set , it'll divide the power making it run at 4 ohms.
Old Jun 14, 2007 | 09:36 PM
4bang6's Avatar
thank you, that's what I needed to know..
Brutewes
May 16, 2006 01:14 PM
Fusiondynamics
Aug 19, 2004 10:32 AM
mcomer
Apr 28, 2004 05:54 AM
seung
Mar 8, 2004 06:21 AM
Hickey322
May 29, 2003 09:52 PM
