Subwoofer choices
Old Nov 12, 2009 | 02:10 PM
WLAURENT's Avatar
Originally Posted by hellspare,Nov 12 2009, 02:37 PM
I've read that alpine does not offer any subs comparable to JL, is this true?
I have listened to most subs on the market. The JL's are nice sounding sub, I would put the Alpine type-R subs somewhere between the W3 and W6 JL subs as far as SQL and SPL and they can be had for less than 1/2 the price of the JL's.
Will PM you
Old Nov 12, 2009 | 02:11 PM
WLAURENT's Avatar
Originally Posted by Jano,Nov 12 2009, 02:40 PM
Do you know offhand if the Alpine sub fits your V1 box?
Will PM you
Old Nov 12, 2009 | 03:17 PM
Neutered Sputniks's Avatar
Hey William
Good to see you around these parts again
Old Nov 12, 2009 | 04:55 PM
hellspare's Avatar
If I were to go for the alpine type r should I get the 4 ohm or 2 ohm? I'll probably be running an alpine mrp m500 as my amp, or something similar in terms of power.
Old Nov 12, 2009 | 05:51 PM
WLAURENT's Avatar
To get the full 500 watts on that amp you need a 2 ohm load. You will want to go with the 4 ohm dual voice coil and run them in parallel.
Old Nov 12, 2009 | 05:53 PM
WLAURENT's Avatar
Originally Posted by Neutered Sputniks,Nov 12 2009, 04:17 PM
Hey William
I have been around - just in other areas of the forums.
Hows things? Getting cold yet?
Old Nov 12, 2009 | 06:21 PM
Things are alright up here.
Getting cold? It never got hot this year
If I could bring the Phx weather up this way, I'd be good
Old Nov 12, 2009 | 07:08 PM
hellspare's Avatar
Okay I think I understand what you mean.
Will 500rms at 2ohm be enough for this subwoofer?
So basically for 1 sub you buy the 4 ohm and wire parallel, and for 2 subs you buy 2 ohms and wire series? Am I getting that right? And in my situation since I'm only running 1 sub I should be buying the 4 ohm version and run it parallel to my amplifier.
Old Nov 12, 2009 | 07:32 PM
WLAURENT's Avatar
That is correct.
hobbes
Mar 29, 2012 08:26 PM
donkeykong
Mar 8, 2009 12:29 PM
SD1S2K
May 8, 2003 11:19 AM
Bonesy
Aug 10, 2002 12:18 AM
axel
Aug 13, 2001 05:49 PM
